Go Back   Automotive Forums Car Chat > Oldsmobile > Toronado
Old 09-27-2010, 08:02 PM
bbfalls bbfalls is offline
dash lights out & automatic lights not working
Well here I post again with yet another issue on the car I love...
92 toro
analog dash with the single line information center.
Just as the title suggests the dash lights are out and the automatic lights (twilight sentinel) not working. The headlights do work however with turning them on the old fashioned way, the switch. I wouldn't so much mind the auto headlights not working again, but its the dash lights that are missed and I would really like to see them working again.
Here is what I've done so far:
  1. I have checked what I thought to be the correct fuses, and I will double check those again.
  2. Slid the auto sensor switch several times, as someone told me once that maybe it would have a sweet spot.
  3. Pushing the overhead courtesy (map) lamps on (manually) does work.
BTW the radio and HVAC lights/LEDs. work, its just the dash, auto headlights (twilight sentinel) and the overhead courtesy lamps that are not working.
Any help you can give would be greatly appreciated.
Signed, Inthedark
Old 09-28-2010, 07:54 AM
maxwedge maxwedge is offline
A990 racer
Re: dash lights out & automatic lights not working
Do the dash lites have a dimmer or seperate control?
Old 09-28-2010, 06:35 PM
yes they do have a separate control...
Old 10-13-2010, 05:34 PM
I wonder, and this is just a guess...could a bad 'photo sensor' (the very small photo sensor on the dash)...be the culprit of all of this? And where in the heck would I get one? and How much? any online resources that are reliable?
Old 10-19-2010, 05:51 AM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Replace your headlight switch . It contains circuitry that controls the automatic operation of the DRL's and regular headlight operation . It also controls the dimming of interior lights when the normal headlights are activated . I had the same problem and replacing the switch took care of it .
" Sometimes I grow so tired "
1998 Monte Dash Lights Will No Longer Work... ermiller79 Monte Carlo 0 12-08-2009 07:35 AM
99 Sunfire Dash Light & Radio Lights turn off when you turn on head lights fathershrubb Cavalier Problem Diagnosis 5 04-20-2009 04:26 PM
Tails Lights & Dash Lights Off & On??? KEVEN1767 Galant 2 10-28-2007 04:35 AM
Automatic headlights not working gm_guy Park Avenue 2 04-10-2004 07:40 AM
automatic windows not working jeepbay Grand Cherokee | Grand Cherokee SRT8 2 11-24-2003 02:36 PM
Tags
courtesy , headlights , lights , sentinel , twilight
