Old 09-23-2003, 01:01 PM
wildemart wildemart is offline
Help! loud screeching sound that stops when I disconnect the battery
Hi, the alternator in my Nissan Sentra recently died, I was able to replace it but now there is a loud screeching sound every time I turn my car on. I found that the sound stops when I disconnect the battery and leave the car running, however, when I reconnect the battery the sound comes back on. I also found that if I just leave the car running, the noise eventually stops on its own and the car appears to run perfectly.
Any suggestions on what might be going on and how to fix the problem would be greatly appreciated.
Thanks.
Old 09-23-2003, 03:31 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
um, slipping belt - needs to be tightened?
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 09-23-2003, 03:37 PM
badassgremlin badassgremlin is offline
Send a message via AIM to badassgremlin Send a message via Yahoo to badassgremlin
but then what would cause it to stop when he disconneccts the battery? that is wiered ive never heard anything like that before
1993 Buick Regal GS 3.8L Hydramatic 4T60E
Old 09-23-2003, 05:33 PM
SniperX13's Avatar
SniperX13 SniperX13 is offline
Send a message via Yahoo to SniperX13
Hows your starter??? I understand that it still works, and starts the car.... but years ago, on my first car, a 92 cavalier, the starter went on it, and there was this loud grinding, buzzing sound, that went away as soon as the battery was disco'd...... maybe your starter is about to give up the ghost as well.
"Who are we to judge those, when we ourselves are afraid to be judged."
Old 09-24-2003, 02:29 PM
Re: Help! loud screeching sound that stops when I disconnect the battery
because the load on the alternator drops, so the load on the belt drops too...
resetting SES light w/o disconnecting the battery clintryplug Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 12-04-2006 06:34 AM
should i disconnect the battery when installing headers? unicyclemidget11 Camaro Discussions 5 03-02-2006 09:27 PM
CVPI Runs bad, if I disconnect the battery and FERNDOGS Crown Victoria 2 10-04-2005 08:39 AM
What happens if your disconnect the battery? mcg 5 Series 2 03-23-2005 10:25 AM
Help! loud screeching sound that stops when I disconnect battery wildemart Sentra | 200SX (USDM FWD) 1 09-23-2003 10:30 PM
