Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 10-02-2005, 07:34 AM
FERNDOGS FERNDOGS is offline
CVPI Runs bad, if I disconnect the battery and
reconnect it temp solves problem
Check engine light was on and car ran bad, idled rough, no power and heistated. After a few minutes I reconnected the battery, the check engine light went out and the car ran great. A few days later it started to run badly again. I disconnected the battery again, reconnected and it runs great (for now)
tHANKS!
2000 CV PI w/4.6L
Old 10-04-2005, 03:52 AM
reekor reekor is offline
Re: CVPI Runs bad, if I disconnect the battery and
Have someone run a scan tool on the car after the light comes on, This will tell you where the problem is.
tHANKS!
2000 CV PI w/4.6L
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 10-04-2005, 08:39 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Agree with reekor. However, do not buy parts based on the code it gives. Post exact code numbers here and we can guide you through the repair.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
