Old 09-21-2003, 11:15 AM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Optima Battery
Which type optima battery would you suggest adding to a system. The best battery please, this is an add-on for car audio, and I want the most power I can get for the battery, without blowing my stuff up.
Old 09-21-2003, 11:29 AM
Deakins's Avatar
Deakins Deakins is offline
What do mean by "add-on"?
Anyway, yellow top, white case.
The ringing of the division bell, have stopped...
AF User Guidelines
Old 09-21-2003, 12:04 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
yep, yellow top is the deep cycle, best for car audio
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 09-21-2003, 01:22 PM
Haibane's Avatar
Re: Optima Battery
I mean 2 batteries instead of one.
Old 09-21-2003, 08:54 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Optima Battery
Like the audiobahn stuff too. Anyway, why not go with a voltage regulator. You can even step up the voltage to a constant 14-16v. It's a great way to cheat more out of the system.
Old 09-21-2003, 09:11 PM
Haibane's Avatar
Re: Re: Optima Battery
Please explain what the above is... and where to get one.
Old 09-22-2003, 12:59 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
ok, why do we want a 2nd battery
Old 09-22-2003, 02:19 PM
sr20de4evr's Avatar
One main battery to start and run the car basically, the other as a deep cycle in the trunk to run the system. I imagine he will ground both batteries to the chassis and run a 1/0 ga wire between the + on the 2 to connect them in parallel. There are many people who have a setup like this, one advantage is that if you like to run your system with the car off you can do it for much longer without worrying about being able to start the car afterwards. It can also be used sort of like a capacitor, and wiring is much easier because your power wire only has to be 3' long or so.
'01 Black Sentra SE
'05 Silver WRX STi
Old 09-22-2003, 05:36 PM
Haibane's Avatar
Re: Optima Battery
I actually was planning on getting it installed for me
yea! optima battery in, but still a couple questions... whiteracer '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 06-29-2003 01:38 AM
Optima Battery civ69 Car Audio 8 06-13-2003 07:00 AM
Optima Batteries!!! DDogg '88 - '91 Civic | CRX | Wagon | Shuttlee 11 05-06-2003 05:11 PM
Optima Batteries on G20? OG20 Audio/Security 3 01-18-2002 11:41 AM
Optima Batteries on G20? wickedG20 Audio/Security 4 01-14-2002 03:10 PM
