Old 09-19-2003, 05:31 AM
2fast2serious 2fast2serious is offline
Help Radiator Fan doesn't work!?
I don't know but it looks like my Radiator fan does not come on.i just bought the ride and does not spin once that i seen or hear.i have a 95.can anyone here help me out with this.how can i test to see if my fan isn't broken?
Old 09-19-2003, 07:52 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
make sure all the wires are connected and none are frayed, touching metal or are just cut period. A good way to test it would be to connect the positive and the negative to the battery and see if you are getting power.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 09-19-2003, 05:24 PM
-=BOOMER=-'s Avatar
-=BOOMER=- -=BOOMER=- is offline
Send a message via ICQ to -=BOOMER=- Send a message via AIM to -=BOOMER=- Send a message via MSN to -=BOOMER=- Send a message via Yahoo to -=BOOMER=-
I thought the same thing with mine so I called asked the dealership, the fan only comes on after the engine temp reaches a high operating tempratue.
If you want to test let the car idle for about 7 minutes and watch the fan. It only turns on when its needed to bring the temp down.
hope this helps.
Old 09-19-2003, 05:46 PM
michaelsd16c michaelsd16c is offline
Re: Help Radiator Fan doesn't work!?
hope this helps.
The fan should turm on a little at 172 full at 194f. To check if your fan switch work's uplug it for the water pump assmbley and stick a paper in the hole(2) just bend the paper clip into a U with the two point going into the hole,with that the fan should turn on. If not then check the fuse in the ECU.
Old 09-19-2003, 07:35 PM
90CRXZCSi's Avatar
there are two fans underneath the hood. Turn on the A/C for a while until the motor gets reaaaalll hot. That should tell you if its working or not.
Old 09-20-2003, 02:19 AM
thanks for the reply of help.i will try those ideas tomorrow.one for sure is i let the car sit running for over 15 mins and no go so it's not that.i'll try the testing to battery and paper clip thingy.
1998 Pontiac Trans Sport radiator fans only work when the AC is turned on amikayla Montana/Montana SV6 1 06-01-2010 12:25 PM
Radiator Fan doesn't work shooitzlinh '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 04-25-2006 08:46 AM
Help! Radiator fan not working--suggestions? kls5834 Grand Cherokee | Grand Cherokee SRT8 3 07-15-2005 04:12 PM
