Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 07-11-2005, 08:23 PM
kls5834 kls5834 is offline
Send a message via AIM to kls5834
Question Help! Radiator fan not working--suggestions?
I looked in the book for the inside fuse panel and didn't see anything labeled about the radiator fan. I also looked in the fuse box under the hood but didn't see anything labeled about the radiator fan there either. The closest thing I saw was "blower motor" which I assumed was for the inside a/c blower. Even though the fuse looked good, I swapped it for another one that looked ok. No change. The fan won't come on without or with the a/c turned on.
I was going to try to jump the fan but couldn't get the connector separated as it comes out of the passenger's side of the fan.
Any suggestions? Help!
Old 07-11-2005, 08:24 PM
oops!
Sorry for not putting this in the original post, but it is a 1999 Jeep Grand Cherokee Limited with about 120k miles on it.
Old 07-11-2005, 08:57 PM
JDPascal JDPascal is offline
Re: Help! Radiator fan not working--suggestions?
Welcome to A/F kls5834
There is a relay for the fan and a fuse in the PDC near the battery......
PM me and I'll be glad to give you some more help with a diagram....
JD
Old 07-15-2005, 04:12 PM
NDH NDH is offline
Had a similar problem recently.
If the fuse in the engine comprtment is good (from memory #10) then I would try to get a voltage reading at the fan conector (when you have the AC on) to see if you have power to the fan.
If you have power from the fuse but not to the fan then it probably is the relay.
This is hidden under the light socket on the passenger side. If you have power to the fan then it is probably the fan.
PM if you have any questions.
NDH
