Old 09-18-2003, 11:30 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Can't get a straight answer...
OK, I can't get a straight answer anywhere. Can anyone tell me if the pistons and rods from the D16A6 and D16Z6 are the same, as far as length and diameter? Are they interchangeable parts? Anyone know??
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 09-19-2003, 01:48 AM
91civicDXdude's Avatar
all pistons from d series 1.5 and 1.6 liter engines have the same bore and thus, are interchangeable. as far as the rods go, they are interchangeable between a6 and z6, but im not 100% sure if they are 100% alike.
Old 09-19-2003, 02:07 AM
hondaracer hondaracer is offline
Re: Can't get a straight answer...
Don't worry about that. You need forged pistons and rods anyway when you get that hp
Old 09-19-2003, 05:35 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
umm.....arent honda pistons already forged.......
and what are you trying to get here? just a higher compression? theres alot of info on Alternative Honda its a D series board with lots of good info
2002 Acura TL Type S
1991 Honda Crx Si
Old 09-19-2003, 09:47 PM
4GZChatch's Avatar
I'm putting a Z6 with a turbo in my new crx, and it had an A6 block that blew on it. 3 of the Eagle rods that were in it are still good, as are 3 of the JE 10.5:1 pistons, (which are for sale, btw, since that will do me no good on a turbo setup...), and I was thinking about using the rods, and getting aftermarket pistons. However, I've looked at the costs of these pistons, and I just can't afford to do that, so I'm just going to go for low boost and build the bottom end later, when I get more $$. I know it would be easier to do it now, with the motor out, but I just don't have the dough. Thanks for the info, in any case. Now I'll know when I do build on the bottom end.
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 09-20-2003, 12:19 PM
kris's Avatar
kris kris is offline
Off playing with fire.
www.dseries.org is a great site too.
Old 09-20-2003, 01:41 PM
dirty91crx's Avatar
dirty91crx dirty91crx is offline
Send a message via AIM to dirty91crx
dseries got shut down...its not d-series.org....better yet go to alternativehonda.com
so whats wrong with a d15b2 again?
Old 09-20-2003, 01:44 PM
kris's Avatar
cool, I havent checked there for a few months
My truck broke down and I can't get a straight answer luthen Problem Diagnosis 10 05-30-2009 11:07 AM
Need straight answers on LS1 fan install... Moze Silverado 9 03-03-2006 07:15 PM
I could use a straight answer. Shick1988 Crown Victoria 2 12-04-2005 10:18 PM
need a straight answer rock0134 Off-Topic 8 12-03-2005 10:31 PM
Idle bounces around, can't hold straight idle ned032002 Off-Topic 6 02-11-2005 05:57 AM
