Old 01-28-2005, 09:13 PM
ned032002's Avatar
ned032002 ned032002 is offline
Exclamation Idle bounces around, can't hold straight idle
I was at a red light today running only at idle and I could feel the car reving a little then letting off. My guess is that it was bouncing around between 500-1000 RPMs and my idle is set at about 800 RPMs and since my RPM gauge doesn't work I really can't say how much play was going on. The CEL didn't trip, the car never stalled at least from this problem, and the problem didn't effect the way the car performed. I checked to see if the intake was loose but no luck there cause I do know that if that's loose then this will happen but will most likely make it stall in a matter of minutes if not seconds. I even made sure that snow hadn't got stuck in the intake vent in the stock body kit/body shape. I don't know what else to check or what else to do.
Old 01-28-2005, 10:15 PM
WildJokers WildJokers is offline
Send a message via AIM to WildJokers Send a message via Yahoo to WildJokers
That would be called Idle surge. Alot of 1gs get it. It can be anything from a vacuum leak to the o-ring on the biss screw crapped out. Check your vacuum lines and if the vacuum lines are fine, i would then check your biss scew. You can check on VFAQ, it should have info needed for the rest.
mods: Driveway hog mod.
Old 01-28-2005, 10:29 PM
TreeFrog's Avatar
TreeFrog TreeFrog is offline
Send a message via AIM to TreeFrog
its called auto rev !!!! just let it do that, everyone at every light will think you are trying to race them!
Something new is coming...
Old 01-29-2005, 07:34 AM
macder macder is offline
Send a message via MSN to macder
Re: Idle bounces around, can't hold straight idle
This is a common problem among all 1g's. There is so much information on this issue around this board and the web. Infact so much information from so many different sources that it is a waste of time discusing this issue. Research the problem, and if there is something allong the line that you are having trouble understading, then ask the forum.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 02-10-2005, 11:30 PM
ned032002's Avatar
Re: Re: Idle bounces around, can't hold straight idle
Actually I did research this problem and had no luck so by posting this question I was looking for help because I already couldn't find any. So do us all a favor and not post things like this cause it gives no advice or help in any way. Thanks and if anybody actually has any advice I would greatly appreciate it.
Old 02-11-2005, 03:16 AM
Wink
http://www.dsm.org/menu.epl?item=35
Took me less than 30sec's
-Stage 2 Crane cams
-Custom header
-Bored 0.5mm
Old 02-11-2005, 05:57 AM
kjewer1 kjewer1 is offline
AF - Advisor
http://www.crebotech.com/
There is a ton of info on this site. There is a troubleshoting link at the bottom. Some others too, including a link to the vfaqs.
Its not that macder was not tyring to be helpful, its just this question has been popular for the last 10 years. That means two things are probably true. 1, there is a ton of info already out there. 2, poeple with the answer are tired of handing it out to people that don't search. Good luck with it.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
