I pulled out my vents last week, and painted them with a silver (my civic is silver) acrylic paint by FolkArt, which I bought at a craft store. My only problem is I already chipped it. It chips off really easily, and around the edges, I even wore off some spots when putting the vents back in. I did the painting over about 3 days, with a total of 3 coats on each of them. How can I keep this from chipping off? Should I be using another kind of paint, or is there some product I can put on over the paint to help seal it onto the plastic? I'd appreciate some advice from anyone who has had success painting the plastic parts of their interior.
96 Honda Civic Daily - H22 Swap 82 Renault R5 Weekend Runner - Nearly Stock 83 Renault R5 Track Car - 13:1 CR, Archer Cams |
be sure to clean the surface completely before you begin painting and I recommend Testor's model paint.
[img]http://communities.msn.com/_Secure/0LQBkb!gPfWxJ!Oenj2OTqeQ7JYQP***2dgF2j3izEbT*KXBpe sJO3hAVY92tSfY6J6jM8KO2kFw/interior.jpg[/img] |
Clean really well... The oils from the dash cleaners will do it. Sometimes its very hard to get all the cleaner of and can require some very very fine sandpaper. The oil will seep deep into the plastic sometimes making it seem almost impossible to get out. Good Luck.
Racing Rice Cars: '97 Civic EX, '02 Explorer Eddie Bauer, '99 Isuzu Amigo 4x4 Bikes: '05 Suzuki DL650 Vstrom, '05 Yamaha Raptor 660R |
use rubbing alcohol to remove any oils on the surface. roughen the surface with fine grit sandpaper to promote adhesiveness. reclean the part with more alcohol.
use an enamel based paint... it's a solvent base that will be virtually indestructable once it dries. Krylon would be a good brand. use very light coats... and use about 3 coats, waiting at least 1 hour between coats to ensure the previous coat has dried. enamel tends to "resoften" itself, so dont shoot layers within 10 minutes of each other... can cause running or "orange peel". hold the can at least 16" away to prevent running, and never start or stop wile adding paint to the surface... use a sweeping motion and start spraying before you sweep over the part, then stop spraying after you've swept past it. this will ensure uniform coating and prevent blotches. |
Here was a post a friend of mine made a good 6 months ago. I helped him do all this, and his vents still look great.
