Old 03-07-2003, 11:55 AM
benie benie is offline
painting interior. need help on what kind of paint.
i read in here awhile back.some guy posted about painting your interior..such as the frame in front of your dash board. or your door handles. so i was thinking of painting mine the same color as my car color. i also read something about primer paint and how you should use that to paint over whatever your gonna paint before you use the color paint.. so anybody know what kind of primer paint i should use or where i can get some? i've never heard of primer paint before.im not sure if i should jsut buy the paint and start painting it. if might not come out right. any suggestions?
Old 03-07-2003, 01:06 PM
wheel1856's Avatar
wheel1856 wheel1856 is offline
Send a message via AIM to wheel1856
well, here goes:
1. Use the search function, type in interior paint, you will get a wealth of threads to help you make a decision on what products to use, how to do it, the pros and cons of doing it, yada yada yada.
2. Everyone on here (minus a few) is gonna tell you that painting your interior is a bad idea. It tends to flake off, chip, and all kinds of other crap.
3. IMO it can be done, but it seems as though, from the threads I have read, that those who did not use primer on their interior pieces have had little or no experiences in paint comming off. (Primer, btw, is basically just another kind of paint that is a little thicker and stickyer than regular paint, it can be sanded and its purpose is to help your color paint stick better and cover better)
4. Should you choose to paint your interior pieces make sure that you prepare the surface VERY VERY well! Clean it clean it clean it with soap and water. then clean it with a rubbing alcohol. get all the armoral and silicone sealers and everythin offf!!!! Then sand it (400 grit), then clean it again, very well, to get all the sanded material off. It is very important that the surface has nuthing but plastic on it when you paint.
read those threads before you do anything, you may find that it may not be worth it. also, I recomend getting the said interior pieces from a junk yard to practice on before doing your own.
good luck
"Why yes, this is a GS-R."
Old 03-07-2003, 01:52 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
My buddy did his with automotive touchup paint and the aforementioned steps and it has yet to flake at all,going on three years.
