Old 09-14-2003, 03:42 AM
mauer mauer is offline
oil use
I got the motor in but about every 20 miles i have to add a quart of oil to it.
it looks like it is coming out the exhaust pipes, which are brand new also.
any ideas why its leaking the oil out and why so fast?
Thanks!
Old 09-16-2003, 02:14 AM
prankstar prankstar is offline
what work was done to the engine?
Old 10-03-2003, 04:45 PM
Erik_The_Red Erik_The_Red is offline
Send a message via ICQ to Erik_The_Red Send a message via AIM to Erik_The_Red Send a message via Yahoo to Erik_The_Red
You probably have a scored cylinder wall, crack in the engine or rings that are toast. You will have to do a compression check and pull the heads to really find out what is wrong here.
Old 10-03-2003, 05:42 PM
Doug000 Doug000 is offline
Send a message via AIM to Doug000 Send a message via MSN to Doug000 Send a message via Yahoo to Doug000
Re: oil use
Thanks!
I have a very similar problem. I just installed a reman. 350 engine into my pickup. All 8 cylinders have a compression between 120 and 125 (so that is good). The electrode ends of the spark plugs in cylinders #2, 4, 6, & 8 are all coated in liqiud oil (like they are dipped in oil); the the other four spark plugs look like the should. There is oil coming out of my tail pipe with a large content of fine metal bits in it (the oil is more silver than brown). I have about 20 minutes of run time on this engine, but I have used a case of oil already. Additionally, large clouds of mostly white smoke (very rarely blue) is coming out of the tail pipe when the engine is started and the amount of smoke is related to engine rpm's.
Any body have any ideas what is causing this??????
Doug
Oil Use 01 vs 99 tsb - please help? n8zdogg Durango 2 12-27-2005 09:13 AM
type of oil used polacek Street Bikes 8 06-19-2005 02:34 PM
oil use joel poulson Aurora 2 02-03-2005 10:35 PM
How much oil use is "normal"? kentreg Caravan | Voyager 1 07-15-2004 06:20 AM
