Old 09-12-2003, 09:58 PM
CRXsk8er CRXsk8er is offline
Send a message via AIM to CRXsk8er
Need Help fast!!!!!!!!!!
Today i removed my intake manifold and valve covers to change gaskets and paint and clean up, I install everything and go to start it it runs rough and blows alot of white smoke. If the throttle body gasket is liike half missing and what is left is worn out will antifreesze flow into the intake and mix into the chambers and burn with the spark and is that what the white smoke is? and why it runs rough. i have check every hose and every vacum line and every plug everything i took off is in the right place i have no idea what to do. Right now my cars at my work in the parking lot i need to get it running tommrow HELP
Old 09-13-2003, 06:58 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
If you removed your distributor, did you double check your timing with the spout connector off? Did you mess with the TPS on top of the throttle body at all? Are all spark plug wires on in the correct firing order?
Yes, coolant can get into the motor if the TB gasket is broken or missing. Did you remove the TB and put it back on with a broken gasket?
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 09-13-2003, 01:52 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Put a new TB gasket on cause it sounds like u just dumping water into your motor. Then pull all your plugs out and crank the motor without the plugs in. Now clean ya plugs check ya timing nd you will prob be ok.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 09-13-2003, 02:18 PM
i did put the broken Tb gasket on the stores were closed i had no choice and what is the tps? today im going to get a new gasket right now ill tell you what happens no i didnt remove the dizzy so its not that but ill take my plugs out and crank it to clean the cylinders out and well see what happens. Thanks for your help guys ill keep you updated
Old 09-13-2003, 04:11 PM
HiFlow5 0's Avatar
Stanger
Re: Need Help fast!!!!!!!!!!
TPS=Throttle Position Sensor. It's the black sensor located atop of the TB. If you didn't mess with it, then don't worry about it.
-2013 Ford Flex
-1999 Ford F150
help won't start!!!! need help fast!!! bigtruckman32 Ram Pickup | Ram SRT10 0 12-16-2006 06:29 PM
Big Problem Need Help FAST HELP!!!!!! 91Intergra Integra 2 09-04-2003 12:23 AM
Need Help Fast!!!!!!!!!!!!! sdss '71-'87 Civic | CRX 2 01-12-2002 06:24 PM
Need Help Fast Willy Estrada Engine 1 01-07-2002 02:14 PM
