Old 09-10-2003, 11:23 AM
76_cobra's Avatar
76_cobra 76_cobra is offline
what would u do?
I bought a cam from Summit, it was a Summit brand cam
their own in house brand and I put it in and broke it
in correctly, I drove it about 300 miles no problems
then I started hearing a loud tapping so I checked my
rocker arms and there were no problems so I added a
little oil, and the noise persisted so I bought a new
set of lifters, pulled the intake and pulled the
lifters and the exhaust lifter for the #1 piston was
destroyed, it had been worn WAY down the wear pattern
was in the shape of a bowl on the bottom of the
lifter, so I called summit and they told me I had a
problem with my lifter bore and that the lifter wasn't
spinning, but if that was the case, then there would
only be one single groove made in the lifter it had to
have been spinning a little to make that kind of bowl
shaped wear they wouldn't do anything except give me a
refund, so I had to spend an entire weekend tearing
down my motor and buying a new cam and replacing the
old one. I think that the Summit cam was ground wrong
the lobe of the cam sat dead center under the lifter
and 3 local speedshops told me that on a hydraulic cam
the lobes need to be a little offset to make the
lifter spin, so my lifter was spinning but only
little bit, after I pulled th esummit cam I looked at
it and the lobe that had been under the destroyed
lifter was flat, what do you huys think was the
problem? this time I put a Crane cam in I was
wondering if this is a good cam?
Degrees Duration @ .050 Int./Exh. Degrees 216/216 lift
.484
Advertised duration Int./Exh. 272/272 lift .484 lobe
separation 110
Are you gonna bark all day little doggie....or are you gonna bite?
Hell of a thing, killin' a man. Take away all he's got and all he's ever gonna have.
Yeah, well, I guess he had it comin'.
We all got it comin', kid.
Old 09-10-2003, 02:04 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Are you using a flat tappet cam? I think you are... So just let me know before I give advice.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 09-12-2003, 09:44 AM
76_cobra's Avatar
Yes it is a flat tappet.
Old 09-12-2003, 11:13 PM
D[X]P's Avatar
D[X]P D[X]P is offline
Send a message via ICQ to D[X]P Send a message via AIM to D[X]P
Nice car dude
Nice animation about hondas sucking!! Did u make it?
Failure is only the opportunity to begin again more intelligently.
Old 09-15-2003, 10:59 AM
76_cobra's Avatar
No I didn't make the animationI got it from another site.
Old 09-20-2003, 04:17 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
new cam
did u replace the lifters with new ones when u installed the cam? cause u have to for the cam to break in and run right.
Old 09-22-2003, 01:27 PM
76_cobra's Avatar
I did replace the lifters as well the cam I bought a cam and lifter kit from summit.
What Beetle do i have adamchrissy Type 1 12 08-20-2013 03:53 PM
What would you do with my truck? Any opinions would be awesome. LT1 Kayker C/K 6 01-18-2005 10:37 PM
IS300 what would u do to this car if you got it GOD IS200/IS300/IS350/Altezza 100 10-17-2004 06:42 PM
What would you do? kris General 10 05-18-2001 10:11 PM
