Old 09-10-2003, 01:49 AM
Riddick Riddick is offline
Handling question
For those of you who have swapped a B16/B18, do you notice a change in handling, like more understeer or something? Is there a difference in braking too?
Old 09-10-2003, 03:25 AM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
There's a touch more understeer, you can tell the front end is a bit heavier when you're cornering hard. No huge difference though. Braking is the same, although I've found I'm braking a lot more now that I get up to speed way faster, and a lot of the time I'm going a lot faster than I intended. So upgrading brake pads would be a good idea.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 09-10-2003, 01:38 PM
CRXtc CRXtc is offline
Banned
when swapping any b-series i recommend the following
integra brakes all the way around (anyone who tells you that the integra steering knuckles will affect your steering geometry should be dragged into the street and shot because it affects neither camber nor caster), with some brembo blanks, aem pads, goodridge ss lines and an 89 integra M/C,90-93 integra prop. valve, ATE Superblue DOT 4 brake fluid and some nice sticky tires
for springs i recommend the following (i have experience with both)
progress auto swap springs (lowering spring w/ proper spring rate for crx w/ b series swap)
or ground controls with a custom spring rate (400 front, 300 rear) for a b-series swap
now if you want extra braking power you can swap a 90-93 non-ABS integra brake booster and M/C into your car, changing the booster is a bitch and then some but it will stop your car even faster, the brake setup i listed to you is what i have now, i will be doing the brake booster and M/C swap on my car sometime in the future so i will have more details then as far as if lines need to be reflared or not......mind you this suspension setup is just for the springs of course, to correct understeer etc sway bars should be installed and other proper suspension components as well
Old 09-12-2003, 01:34 AM
Thanks for the help/advice! Much appreciated.
Old 09-12-2003, 09:22 AM
Banned
Re: Handling question
no problem
Shaved Handle Questions 93CivicSiD16HB Exterior | bodykits | Lighting 1 03-08-2006 05:57 PM
handling question grncivicdhr Mustang Talk 13 02-10-2004 05:41 PM
Front Assist Handle Question jlaird Aurora 1 11-02-2003 04:14 PM
Handling Question Prelewd Prelude 4 12-09-2002 10:08 AM
Handling Question Tarnsman Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 07-09-2002 02:10 PM
