Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 09-06-2003, 10:59 PM
Real GTR's Avatar
Real GTR Real GTR is offline
Send a message via AIM to Real GTR
2.8 HKS Stroker kit
Has anyone in the US ever done or has a HKS 2.8 Stroker kit. If so can u give me some deatails about the pros and cons about it.
Old 09-07-2003, 08:53 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Yes, there have been a couple of guys that have done them. Not me, too much money.
Pros, more cubes = more torque.
Cons,
RB26DETT is not meant for torque, so its almost pointless. IMHO
In order for samller displacement engine to make power, they need to spin. Increase the stroke, you have more chance of something letting go. Plus more cubes will have a inverse reaction to the power band at the higher RPMs. In other words, you will make less power. At least from the engines that I have seen.
Cost $$$$$$
This is the way I look at it, if you want good power out of the RB26DETT you cannot go wrong with a set of 2530. They are direct bolt ons, plus the drive train can handle almost all the power it can put out. If you want more power than what the 2530 can put out, you are going to have to dig deeper into your pockets, because the engine will need some major work and upgrades, plus the tranny will need to be strengthned.
The GT-SS are a quicker spoolin turbo, but the 2530 have a little more power at top end. It all depends on what you want.
I would not go with a 2.8stroker kit, there are much cheaper way to get the power out of the engine.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 09-07-2003, 01:24 PM
RazorGTR's Avatar
RazorGTR RazorGTR is offline
Skyline Man
Another drawback to the kit is, unless you are using the N1 block you could very well wind up having block failure. In other words cracking between the #3 and #4 cylinders. Even with the N1 block pushing more than 950hp out of it there is still a danger of block failure.
Also if something goes wrong and you need to change anything internally it is very expensive as everything is different compared to normal aftermarket parts.
At the end of the day unless it is a fully sponsored race car, this kit is hardly worth it. There are two GTR's here in NZ making over 1,300 hp with the original bore and stroke dimension, well bored out for forged pistons.
You don't own a Skyline, then don't cry to me about it!
1992 Silver R32 GTR tickled to 450hp. - Sold when I left NZ in 2004
Arguing on the Internet is like competing in the special olympics. Even if you win, you're still retarded.
Never confuse kindess with weakness.
AF user guidelines, Please remember to abide by them
Old 09-07-2003, 03:49 PM
Real GTR's Avatar
Thank you you save me some time and money.
How do you think I shoud go about it, my goal is to have around 800hp at the tires but I was told that the stock crank would only hold 7-8. So that's why I was thinking about the 2.8 kit it comes with everthing I'd need rods pistons and crank. I tought I'd come out cheaper buying the kit.
Old 09-07-2003, 05:13 PM
SkylineUSA's Avatar
800hp, how long do want the drive train to last?
As soon as you go above 550ish, that is when you really need to do some major mods, if you want 800hp to the ground, not to mention you are talkin a lot of cash.
What are your intentions for the R33? Do you have a list of what and how you want to achieve 800hp?
Old 09-08-2003, 01:29 AM
Real GTR's Avatar
I'm willing to do what ever it takes this is my show car so I don't drive it everyday. I bearley drive it at all. I plan on trying to building it over the next year I just want to build it right. I don't want to have to keep going in the motor to add things unless I'm fixing something..
I was thinking 1000cc injectors,280 intake and exhaust cams, HKS rods,rings,pistons, maybe even crank. 3 fueal pumps,2 HKS 3240 turbos, etc,etc everything. I 'm even looking into a OS Gilken Transmission
Old 09-08-2003, 02:28 AM
S13GTR S13GTR is offline
I have a rb26dett and I have never heard of a N1 block. Whats the difference? Sounds like its a lot stronger. If so how much hp can my stock block and head gasket hold? Im already pushing 400 rwhp.
Thanks guys.
Old 09-08-2003, 11:11 AM
SkylineUSA's Avatar
Real GTR ,
280s are fuckin huge.
3 fuel pumps, why. You can buy one that will be able to support 800hp.
2 3240, lag will be your friend, unless you get a little shot of the funny stuff, direct port of course.
With that combo, 800 will be doable.
S13GTR ,
N1 blocks have a little more webbing if I remember correctly. Mario is putting out over a 1000hp with a stock block. But, like all big power engines they are all on borrowed time, now aren't they.
400rwhp, what rear end do you have? What mods do you have?
Old 09-08-2003, 01:28 PM
Real GTR's Avatar
I looked a little into buying a N1 at Taka Kaira Inc but they could tell if I'd get the motor tell I placed the order/paid for it up front.
My dirrect port should be here this week. But just ran into another problem, I have a oil seal leak from one of my turbos.The guy that is going to build my motor is really trying to discurage me from doing so much HP. After what just happened I may need to rethink everything.
I have the five speed tranny in here now, will the six speed directly bolt in? And which fuel pump were you talking about? Also I was told two different thing that it is and isn't sequental could u please enlightn me?
Old 09-08-2003, 01:52 PM
RazorGTR's Avatar
Skyline Man
I've moved this here as it is a good thread and now fits this area.
800hp at the wheels isn't a huge ask. It will however take some dosh to get you there as one would expect. You're choice in cams will put you there but you realize you will need to have the head machined for clearnce of the cam lobes. Also you are looking at springs, retainers, porting, and a custom manifold.
Pistons are you're choice. JE's are fine. Trust use their blanks but charge 2 1/2 X the price. HKS, Jun, etc are no better and all cost more. Your factory crank will support your power depending on how you drive. If the car winds up a drag car it won't last more than a full season if you're lucky. Normal driving where you are not giving it death all the time who knows, could last a long time.
So you are looking at the following:
ECU: PowerFC, Link, Motec, etc.
Rods: Carillo, HKS, Jun, etc
Rodbolts: ARP!
Pistons: JE unless you want to pay for a name
Block: Bored to fit the pistons
Head: Cams, Retainers, lifters, springs porting, machinng
Cams: 280's if that is what you want or even 264's
springs, retainers, lifters: HKS, Jun, Trust
Intercooler: 600x300x120
Turbo(s): There are many combinations. T88, T51R, HKS 3037'S, GT30'S name a few.
Fuel pumps: apexi x2
fuel pressure regulator: Malpassi large
OS Giken gear set for the trans or spend $10,000 + for a complete trans
I would also suggest a swirl pot for the fuel.
There are so many different combinations to go with, a the end of the day though it will boil down to how deep your pockets are.
Old 09-08-2003, 04:32 PM
SkylineUSA's Avatar
Fuel pump...Weldon a2025
With everything you want to put into that car, you could afford a small country.
? What do you mean?
Old 09-08-2003, 06:40 PM
tofstchvy tofstchvy is offline
Send a message via AIM to tofstchvy Send a message via Yahoo to tofstchvy
This is what I did to my car.
Nissan N-1 racing block
HKS 2.8l STEP 3 stroker kit
HKS 280 STEP PRO V Head system
HKS Adjustable Cam Gears
HKS Oil Pump
HKS T-51 KAI SPL BB Turbo
HKS GT Wastegate
HKS 4 CORE GT Series Intercooler
Custom Fabricated Surge Tank
Power Enterprise 6X1000cc and 6x800cc injectors
HPI R1 Oil Cooler
Trust Deep Sump Oil Pan
Radiator Brass 3 core
HKS F-CON V-PRO Computer
HKS Triple plate clutch
O.S. GIKEN Cross Mission
Cusco front and rear L.S.D.fs
HKS front and rear axles
NISMO Rear Lower Control Arms
NISMO Rear Upper Links
NISMO Front Lower Control Arms
HPI Pillow Ball Tension Rods
Stainless Steel Brake Lines
HKS Pro Start
GREDDY Gauges
Boost, Fuel Pressure, EGT, Oil Temp, Oil Pressure
HKS AIC
HKS Torque Split and Drag Adapter
HKS EVC 3
Hurst Linelock
Aeromotive 1000 fuel pumps x 2
853 to the wheels at 1.8 boost. Safe to 2.5 boost levels. I spent over $40,000 in parts alone and that was at cost. Did all of the fab work and assembly myself.
http://www.joulespeed.com
Old 09-08-2003, 10:06 PM
Real GTR's Avatar
I at least decided to go with the 3037's. Everything else will probly be HKS or Nismo.
I don't race much if at all so the crank should be ok.
Is there anyone in the US other that Motorex that can get nismo skyline parts? and is that transmission a direct built in? Would I still be able to run 94 oct or would I strickly need to run on race gas? Also how would the driveshaft hold up?
Hey Razor on the mirageautosports.com web site they have the OS Trany for 928,000 yen=7,789.18 (U.S) how did you come up with the 10,000 g's figure.
Old 09-09-2003, 12:27 AM
abuC abuC is offline
If you're going to go with a stroker kit, might as well check out Crower...
http://www.crower.com/cat/stroker.shtml
Taka Kaira is selling brand new complete N1 engine's for $7000, you can get an N1 shortblock for $1400 or so I've heard.
Real GTR, are you from NY?
Old 09-09-2003, 04:31 AM
RazorGTR's Avatar
Skyline Man
Re: 2.8 HKS Stroker kit
OS Giken tranny isn't much better than the gear/shaft set. There is nothing in the box strenght over the factory one. $10,000 would be for a Holinger or simular. I can get OS Giken gear sets for $5,000 NZD or about $2,500 USD ex-Japan through a contact.
Help with timing 85 GT 2.8L 4SP unsalvaje Fiero 1 05-23-2010 09:33 PM
hks 3.4 stroker kit Dead-Wyrm Performance 2 06-20-2004 03:02 AM
2.8 stroker kit tazz311311 S-10 8 03-13-2004 01:14 PM
2.8-3.4 stroker kit+ 3.1 crank pistons jumpman1203 S-10 1 12-22-2003 08:04 AM
TODA 2.3 or JUN2.2 stroker kit? EVO_ARTIST Lancer 4 08-30-2003 12:59 PM
