Old 09-03-2003, 04:35 AM
Whitetrash Whitetrash is offline
Teouble shifting Getrag 5-speed into 3rd-4th
I can't get my shifter into 3rd or 4th gear. It is apparently a shift linkage problem. Anyone know if I have to remove the tranny to get inside it to fix the shift linkage problem? Thanks.
Old 10-03-2003, 03:31 PM
Erik_The_Red Erik_The_Red is offline
Send a message via ICQ to Erik_The_Red Send a message via AIM to Erik_The_Red Send a message via Yahoo to Erik_The_Red
Exclamation Re: Teouble shifting Getrag 5-speed into 3rd-4th
I had a similiar problem in first and second gear. No, I did not have to remove the transmission. What I did was remove the shifter and assembly so the I could see into the transmission from the top inside the vehicle. There should be a rolled pin in the shifter assembly on top that has sheared in half. You need to drive this pin out without dropping it into the transmission and then replace it. The pin costs less than a dollar and can be found at Ace Automotive or Ace hardware. If this is not the problem your syncros are probably shot and need to be replaced.
Please Help, '99 AT Mitsu Eclipse won't shift into 3rd '99EclipseProblems Engine, Transmission and Drivetrain 6 09-13-2009 10:03 PM
90 accord dx 5 spd 2genjohn Accord/TSX/Accord Hybrid 1 04-04-2009 06:50 AM
Can I put a 5-speed in an 84 Fiero? Protoclown Fiero 1 03-23-2009 12:08 AM
2001 tahoe won't shift into 3rd or 4th rubba Engineering/ Technical 1 06-07-2005 12:20 PM
Tranny Won't Shift Into 3rd And 4th jensterny Blazer 15 09-30-2004 05:22 PM
