Old 09-03-2003, 02:30 AM
birdchua birdchua is offline
Question Gloss coat first or polish first
I have just started on my first model . i used tamiya acrylics gloss red mixed with IPA. I have put a couple of wet coat and it still appear dull. ( read that it happen when tamiya gloss is mixed up IPA)
What should i do to make it shine?
1) polish it using rubbing compound and wax then put a gloss clear coat
2) put a gloss clear coat first the polish it with rubbing compound and wax?
Thanks
Old 09-03-2003, 03:24 AM
RallyRaider's Avatar
Zomby Woof
I wouldn't recommend painting after polishing. Depends what you're using but the polish could leave a barrier that will prevent the subsequent coats from bonding well. Could lead to fisheyes or peeling layers of paint.
If the paint is thick enough and you're only using one single non-metallic colour then clear coating isn't absolutely necessary.
Old 09-03-2003, 09:48 AM
malsheem's Avatar
malsheem malsheem is offline
20 inches and growing ...
Use some cutting compound on the paint and make the paint smooth. Then spray on a nice wet gloss coat, then use cutting compound on the gloss coat, and polish.
Like RallyRaider said, polish is a last step. Don't paint after you've polished.
-Joe
www.quietrage.com
CWest R34 Skyline GT-R
Old 09-03-2003, 10:05 AM
thank for the advice. but what do you mean cutting compound? do you mean rubbing compound???
Old 09-03-2003, 10:10 AM
malsheem's Avatar
Re: Gloss coat first or polish first
Yeah, rubbing compound. Same thing, people just call it different names.
-Joe
www.quietrage.com
Flat base clear gloss coat? White primer Grey Primer? AllAlone.Gz Car Modeling 4 12-25-2006 06:42 AM
Do I have to clear coat to polish? aN4rK1 Car Modeling 11 04-30-2005 12:55 PM
Gloss Coat g-unitcustoms Car Modeling 6 07-26-2004 06:29 PM
Clear coating and polishing?? Davoaldo Car Modeling 6 10-22-2003 06:38 PM
Clear coat after polishing? spoolin12 Car Modeling 6 07-05-2003 09:00 PM
