Old 07-05-2003, 06:05 AM
spoolin12's Avatar
spoolin12 spoolin12 is offline
Send a message via MSN to spoolin12
Clear coat after polishing?
Hey, I knwo its a dumb question but once i have painted my car (yellow) and then polished it, should i put a clear coat over that or do i do no clear coat at all?
Thanks
Old 07-05-2003, 06:08 AM
spoolin12's Avatar
Ohh and yes i did look in the FAQ section but couldnt see anyhting about clear coating
Cheers
Old 07-05-2003, 06:46 AM
ales's Avatar
ales ales is offline
Forza Schumacher
Cheers
Well, it's there. I know this because I wrote it. Look for the post on which order one should perform the process of painting the body.
Also might help if you mentioned what kind of paint you used.
Old 07-05-2003, 07:06 AM
spoolin12's Avatar
Ok sorry i could find this, but it says nothing about clear coating
1. Solid colour (non-metallic):
a) primer
b) sanding the primer if necessary
c) paint (several coats)
d) sanding (if rough orange peel)
e) cutting/rubbing/polishing - whatever you call it - compound. By the end of this step the paint should be smooth as a baby's butt!)
f) decals
g) wax
(im using tamiya chrome yellow)
Old 07-05-2003, 07:46 AM
joecwlaw's Avatar
joecwlaw joecwlaw is offline
hey spoolin12, if your car has a lot of decals on it, you should clear coat to protect the decal. Otherwise, if just some emblem decals, I would not do any clear coat. just a little suggestion to you, hope it helps.
FAQ here you go http://www.automotiveforums.com/vbul...997#post578997 <==not sure who wrote it
a) primer
f) decals
g) wax
Old 07-05-2003, 08:50 AM
bah humbug's Avatar
Keep reading you lazy FAQer.
Why would you want to clear if it's not metallic. Even if you do have a lot of decals.
Alternatives -
YOu could have put a couple of coats of paint. Sand + Polished. Put decals then Tamiya wax.
Or you could have Painted, put decals, then cleared (make sure you have enough so when sanding you don't go though clear and sand decals) Then sand polish.
Old 07-05-2003, 09:00 PM
spoolin12's Avatar
Thanks guys!
Complete:
Decals - Clear coat & Sanding grit Zman007 Auto Collision Network 1 12-24-2010 07:52 AM
Do I have to clear coat to polish? aN4rK1 Car Modeling 11 04-30-2005 12:55 PM
Clear coat after decals? ore Car Modeling 17 07-09-2004 12:50 AM
Clear coating and polishing?? Davoaldo Car Modeling 6 10-22-2003 06:38 PM
Rubbing/Polishing before clear coat. djmr2 Car Modeling 10 06-28-2002 05:42 AM
