Old 09-03-2003, 02:05 AM
pmarque pmarque is offline
Sanding question
I read in some posts about wet sanding.
My question is in what situation should we use wet sand and "dry sand"?
Best Regards
pmarque
Old 09-03-2003, 02:25 AM
malsheem's Avatar
malsheem malsheem is offline
20 inches and growing ...
Re: Sanding question
Best Regards
pmarque
I wet sand during the whole primer, painting, misty coat, orange peel, wet coat, and compound process.
I dry sand pre-primer. Smoothing out putty or body panels before laying down primer.
Not sure if this follows any sanding rules, but it has worked for me, so I've stuck to it.
-Joe
www.quietrage.com
CWest R34 Skyline GT-R
Old 09-03-2003, 10:38 AM
Is there any special process to wet sand?
Or you just wet the sand paper in cold/hot water?
thanks
pmarque
Old 09-03-2003, 10:47 AM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
Nothing special to it, just keep the paper wet. I either do it at the sink or in a samll container. A little soap in the water helps keep the piece clean and lubricates the paper as well.
Murray Kish Murray Kish is offline
Getting Old...
I'm not sure if there really is a 'wrong' time to wetsand. Wetsanding just lubricates the surface and makes the sandpaper work a whole lot better. It clears away any of the tiny debris and allows the sandpaper to keep working without getting gunked up.
The only down-side is that it's a bit messy and you need to let the parts dry after you're done.
I generally wetsand as much as I can for body parts and other major components. Minor parts don't get quite the pampering...
Murray
Sanding question. badboy00z Car Modeling 1 08-03-2005 03:57 PM
Sanding questions StephenDeli Car Modeling 7 02-22-2004 03:44 PM
Important: Sanding Question Headlight Car Modeling 4 11-10-2003 03:38 PM
Sanding Question DanSmith Car Modeling 5 03-20-2003 09:27 AM
priming + sanding question dgdarien Car Modeling 1 04-08-2002 05:58 AM
