Old 04-08-2002, 03:34 AM
dgdarien dgdarien is offline
priming + sanding question
okay okay, so i'm still new at this. and i just put on the first layer of primer on the model body. and i read in Guiddy's WRX post that the primer needs atleast 24 hours to dry.
does the primer need 24 hours between each coats to dry? or does it mean after the final layer of primer has been applied to wait 24 hours. also do i sand after each layer of primer? thanks guys!
Old 04-08-2002, 05:58 AM
Tyrell's Avatar
Tyrell Tyrell is offline
Re: priming + sanding question
Originally posted by dgdarien
Does the primer need 24 hours between each coats to dry? or does it mean after the final layer of primer has been applied to wait 24 hours.
Leave it for 24 hours after the last layer before sanding. Leave it for a couple of hours at least between each coat, though. If you do thin layers, they'll dry quicker!
Also do I sand after each layer of primer?
No. Only sand after the last coat or you'll get dust trapped in the next layer. Again, if you do it in thin layers, there should be no real need to sand between layers...
Regards
Mark
Current Project:
Sanding question. badboy00z Car Modeling 1 08-03-2005 03:57 PM
Sanding questions StephenDeli Car Modeling 7 02-22-2004 03:44 PM
Important: Sanding Question Headlight Car Modeling 4 11-10-2003 03:38 PM
Sanding question pmarque Car Modeling 4 09-03-2003 10:47 AM
Sanding Question DanSmith Car Modeling 5 03-20-2003 09:27 AM
