Old 09-01-2003, 08:16 PM
3.8_83STANG 3.8_83STANG is offline
reat end ratio
hello,
I was wondering if anyone, knows the rear end ratio, for a 1983 mustang glx V6, automatic trans.
larry
Old 09-01-2003, 10:43 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: reat end ratio
Originally Posted by 3.8_83STANG
hello,
larry
There's a couple different ratios it could be. You have to either find the axle code located on the drivers side door tag, or crawl under the car and find the axle tag attached to the rear diff cover. If you can find either of those write down the info and post it back here.
You could also check the old fashioned way. By jacking the rear of the car up and turn the rear tire one complete revolution. While you turn the tire one revolution, check to see how many times the driveshaft spins. The number of times the driveshaft turns will give you an approximate rear end ratio.
-Craig
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 09-02-2003, 12:29 AM
vbrpete vbrpete is offline
I've seen about 200 V6 Stangs and T-birds,and EVERY ONE had a 2.73 open 7,5" diff.Doesn't mean it hasn't been changed,of course.
By the way,unless your motor is modified,don't go beyond a 3.27 axle for it-the V6 really doesn't like to rev beyond 4000 so a higher gear is a waste of time.
Old 09-02-2003, 08:50 AM
HiFlow5 0's Avatar
Stanger
Since the car is an 83 there is still a possibility that there is a 6.75" rear in there. With either 2.26, 2.47, 2.73, 3.08, or 3.27 ratio gears, but a 2.73 is a more common gear choice with the automatic tranny, as vbrpete said.
-2013 Ford Flex
-1999 Ford F150
rear end ratio dogshowvan Express | G Van 2 04-16-2005 01:01 PM
rear end ratio NoS287 S-10 3 04-07-2005 10:56 PM
Suburban rear end ratio question retrac Suburban 7 03-04-2005 10:04 AM
rear end ratio j9972136 Camaro Discussions 11 11-08-2004 08:30 PM
Rear End Ratio? wmriceman TrailBlazer | Trailblazer EXT 4 08-11-2004 06:36 PM
