Old 11-06-2004, 12:15 PM
j9972136 j9972136 is offline
Question rear end ratio
Does anyone know what ratio comes stock in my 94 3.4L, also recomended higher ratio Thanks
Old 11-06-2004, 12:43 PM
Dober89 Dober89 is offline
Re: rear end ratio
I would guess that its a 2.73 for automatic and a bit lower for manual maybe 3.42 but im not sure about the manual gearing.
I changed my 2.77s out for 3.27s and they made a noticable difference and didnt kill my cruising rpms too bad. The highest I would have gone is 3.45s with my auto tranny though.
Old 11-07-2004, 03:09 AM
redz2897 redz2897 is offline
Send a message via Yahoo to redz2897
Re: rear end ratio
according to SS world.com you should have 3.23
Old 11-07-2004, 03:11 AM
Re: rear end ratio
Sorry I forgot to suggest new ratio. in my 97 z28 auto I have 2.73 they work out good out on the highways but off the line I dont like them that much I want a little more off the line
Old 11-07-2004, 03:39 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: rear end ratio
Get a 3.73, that's a good all around FDR for street and strip.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 11-07-2004, 05:02 PM
96CamaroSS's Avatar
96CamaroSS 96CamaroSS is offline
Re: rear end ratio
V6 camaro's usually came with 3:08 ratio, but you could have got 3:23's if it was a stick. 3:42 was only a V8 6 speed ratio... Depending on the year of your car check the RPO code list. It's located in the glove box on the 93-95 camaros's and on the drivers door on the 96-02 camaro's.
GU2 = 2.73
GU4 = 3.08
GU5 = 3.23
GU6 = 3.42
If you are changing your gear ratio on an automatic. I would go with 3.42's or 3.73's. Remember your speedo will be off until you reprogram your computer for the gear change.
Old 11-07-2004, 06:54 PM
slim84maro slim84maro is offline
Send a message via AIM to slim84maro
Re: rear end ratio
3.73's suck on the highway. i top out at like 120-125 with these gears. and thats at 4500rpms but damn to i gett going quick. crusing at 65 even with od your still at like 3000 rpms or something near that i dont remember ill check next time at that speed
check out www.v8havoc.com
Old 11-07-2004, 08:13 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: rear end ratio
i wouldnt go higher than 3.42 or 3.45 for street use, im putting 3.27's in mine.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 11-07-2004, 09:51 PM
Re: rear end ratio
3.27s is the shiznit for tpi iroc :P
Old 11-07-2004, 10:07 PM
89IROC&RS's Avatar
Re: rear end ratio
thats what i say, cuz it means you got the 9 bolt
Old 11-08-2004, 03:03 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: rear end ratio
if you have an auto you have 2.73 on the 94 3.4. i just put 3.42s on my 94 auto and my gas mileage wasnt affected at all. i cant notice a difference on the highway in terms of RPM (meaning its minimal, i know that it has to change) and the acceleration is a lot better. the 3.73s i think would be better cause i dont see them having too major of an effect on driveability. but if you are worried about gas and top speed, i would recommend 3.42s...
*Better power-to-weight ratio than a C6 corvette*
Old 11-08-2004, 08:30 PM
Re: rear end ratio
Thanks, i'll probobly go with a set of 3.42s then
