Old 08-26-2003, 05:36 PM
Silencer_Nate's Avatar
Silencer_Nate Silencer_Nate is offline
The Night Assassin
How can you tell the engine?
I'm looking to buy a 01 Camaro SS but was curious, how exactly can you tell the difference between a LS1, LS6, and LT1? Is it clearly posted on the enigine somewhere, or do I have to check the VIN/ enigine number, etc.?
'02 Camaro SS..."almost" stock.:sarcasm1:
Old 08-26-2003, 07:34 PM
triplerc triplerc is offline
Send a message via AIM to triplerc
well 93-97 are LT1 and 98-2002 are LS1
not sure about the LS6 though...
Old 08-26-2003, 08:52 PM
BlkCamaroSS's Avatar
BlkCamaroSS BlkCamaroSS is offline
Send a message via AIM to BlkCamaroSS
Well, since you have an 01 SS, and not a Z06, chances are immensely in the favor of it being just an LS1. There are rumors that a few F-bodies made it out of the shop with LS6's in them, but I've not ever seen one of those in person, unless it was a conversion after the fact. You'd check the engine codes on the transmission, if I'm not mistaken.
2001 Camaro SS #2239 of 6332
1/4 mile time: 13.575 @ 105.55 mph, 60' time: 2.276
307.1 rwhp, 330.1 rwtq = 353.2 hp, 379.5 lb ft torque
Options: SLP Front Grille w/ SS Center Logo, 17" ZR1 Chrome rims, 6 speed, Hurst Short Throw Shifter, Monsoon 500 Watt Sound System, T-tops, 1LE Performance Suspension
Mods: Holley PS Air Filter, SLP Air Box Lid w/ Mr. Ed's pipe fix, SLP CAI, SLP Bellows, SLP LM, SLP Y-pipe, SLP 160 Thermo, SLP Temp Module, SLP STB, KBDD SFC
Old 08-27-2003, 12:12 PM
daeckert daeckert is offline
I'm gonna agree with blkcamaroSS, I've never seen a LS6 camaro. I read that when the new camaros come out in 05-06 they will have LS6's in the Z28's. But buddy is correct in which year had what motor.
Old 08-27-2003, 05:21 PM
The Night Assassin
Thank you for explaining how to tell...I've decided that I want the 02, and will be buying shortly. (I never said I OWNED an 01 ;-)) I now know fairly for certain that I'll have a LS1 under the hood. That's what I needed...Thanks
Old 08-27-2003, 10:03 PM
Gripenfelter's Avatar
Gripenfelter Gripenfelter is offline
Honorary Mod
Send a message via ICQ to Gripenfelter
Some 02 Fbodies came with the LS6 block but they all have LS1 heads.
The revised LS6 block has better oil passages and is a bit stronger than the regular LS1 block.
LS1 and LS6 have a plastic intake manifold. For 2002 the LS1 has the LS6 intake as well.
LT1s were aluminum intake manifolds.
Old 08-27-2003, 10:07 PM
The Night Assassin
I can only assume there are aftermarket intakes to switch out...*imagining the engine dying, looking under the hood and seeing a big melted plastic mess*
Old 08-27-2003, 10:35 PM
Honorary Mod
There are no aftermarket intakes for the LT1 unless you wanna count the LT4.
The LS1s have an aluminum one made by holley but I don't know anyone that has bought one.
And the only way you would melt a plastic LS1 ntake is if your engine caught fire. In that case the intake would be the least of your worries.
Old 08-27-2003, 10:52 PM
The Night Assassin
*makes a note to place "joke:" before attempting at humor again*
Old 08-28-2003, 07:41 PM
2001 LS1's had LS6 intakes as well...
Old 09-01-2003, 07:32 PM
pimpmaro's Avatar
pimpmaro pimpmaro is offline
Send a message via ICQ to pimpmaro Send a message via AIM to pimpmaro
The composite LS1 and LS6 intakes IMO are great. No heat soak!! The only problem is them standing up to high boost and Nitrous.... From what I've heard, the holley isn't much different at all than the LS6, but right now, Futral Motorsports has a sheetmetal intake designed for Large cubes and high reving race engines that shows 10-20 rwhp over the LS6 intake... ALSO, it is rumored that Fuel Air Spark Technologies is coming out with the LSX intake that looks almost exactly like the LS series intakes from GM and the one from Holley, but it out performs them all. I'm personally waiting for dyno graphs since the Futral intake is more than my setup needs right now.
How can you tell a LS1 Engine? Zyphyer Camaro Discussions 15 07-14-2006 10:29 PM
How can you tell the dif between the stock kl03 engine and the klze doorknob329 Probe 3 04-19-2005 01:17 PM
How can you tell the difference between a 305 and a 350? MajorProblems Camaro Discussions 4 10-15-2003 10:26 PM
How can you tell if there was sugar in the gas tank? Kingdave Engineering/ Technical 4 07-12-2003 03:48 PM
how can you tell which engine is which?? imports_only1 Accord/TSX/Accord Hybrid 1 06-10-2003 11:08 AM
