Old 08-26-2003, 04:41 PM
z5ctz z5ctz is offline
b16b
what all can you do to a b16b to get more power while keeping it n/a
tia.
Old 08-26-2003, 04:56 PM
would it be cheaper and better to n/a a ls/vtec or b16b. which would have more hp in the end and which has better support.
Old 08-26-2003, 05:42 PM
projectsilvia97's Avatar
projectsilvia97 projectsilvia97 is offline
Send a message via AIM to projectsilvia97
if you wanna go n/a, i suggest you not go with those engines. the ls/vtec is mostly for the turbo application, since of it's taller gears. a b20 vtec is a good choice for an n/a. that or a b18c5. those would be one of my choices.
Old 08-27-2003, 01:54 AM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
Re: b16b
Actually an LS/VTEC is a great motor for NA. The hp/trq that it produces is amazing. Yes the longer gear ratios are best for turbo applications but that applies to the tranny and not to the motor itself. An LS/VTEC w/ a 98 spec ITR tranny is a deadly combination.
If you have a B16B, stick with it. There are stroker kits and aftermarket cams that still increase hp and trq not to mention ways to bump compression.
Old 08-27-2003, 10:17 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: b16b
tia.
I want to do the same. I've freed about 10hp with an intake and exhaust but that's not enough... I'm content with it stock but if there are any worthwhile parts then I'm all for it.
Old 08-27-2003, 11:01 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
get a set of equal lentgh header, maybe upgrade the cams/cam gears, and get a fuel and ignition upgrade.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 08-27-2003, 11:12 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
You can get THIS
Old 08-27-2003, 03:07 PM
boosted331 boosted331 is offline
Re: b16b
lol, you sure know what you're talking about. Don't get the B18B for N/A because it has long gears, but get on the B20 train which has the exact same tranny! woo woo!
If you have a B16B, keep it. If you havn't bought a swap yet, a B16B is a waste of money. GSR motor with a portflow head, coated CTR pistons, cams, full exhaust and hondata will make a ton of N/A power and cost less than the B16b.
Old 08-27-2003, 03:41 PM
Ricochet's Avatar
Banned
Yeah but then there's the installation time, dynotuning etc... where a B16B is already tuned to near perfection from the factory. I bought the "packaged deal" and can live without the little extra power a hooked up GSR could provide. I'm not saying either one is right or wrong, just a matter of if you know what your doing or not. I'm not a mechanic, and hooking up a GSR engine by paying a shop to do it all would way outcost a B16B.
Old 08-27-2003, 04:13 PM
does anyone know where i can find a site that is dedicaded to this b20 because i would like to find out more.
tia
Old 08-27-2003, 07:05 PM
www.b20vtec.com
or just type in b20vtec at google. that works also
Old 08-27-2003, 07:15 PM
does anyone know of anymore
tia.
Old 08-28-2003, 07:06 PM
does no one else know any sites. Well i tryed looking for some on google but couldnt find anything about b20.
Old 08-29-2003, 08:42 AM
Ricochet's Avatar
Banned
Re: b16b
Obviously not because nobody replied.
what's better for swap B16b, B18c1, B18c5 liquid8 Engineering/ Technical 8 02-13-2002 12:13 AM
B16B (96-00 Civic-R ) Engine SUPERCHARGER vs. TURBO 2800.2CVC Forced Induction 5 01-18-2002 05:30 PM
b16b block or get the b20z b16b bomber '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 01-09-2002 08:09 PM
Converting B16B to 1.8 b16b bomber '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 12-03-2001 12:25 AM
b16b engine b16b bomber '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 8 11-19-2001 10:05 PM
