Old 08-25-2003, 11:18 PM
euroAccorDeuro euroAccorDeuro is offline
H22 vs H22a?
Whats the difference between an h22 and an h22a? Don't they both put out about 220 hp? I know that an h22a is more expensive whys that? Also, once i do a swap to an h22, will my intake and other engine components fit right on the h22 from my f22?
Old 08-26-2003, 02:45 AM
94tegRS's Avatar
94tegRS 94tegRS is offline
the H22a pushes 195 USDM and 200 JDM i think, the type S is the 220 HP one. and i think that the H22 is the H22a and some people just call it H22 and dont put the A cuz if you are talkign with someone who doesnt know what the H22 is i doubt the A is gonna help them understand, but in the b18's the letter is very important which is why you usually see the letter in discussions. at least that is my thought on the matter
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 08-26-2003, 10:00 AM
streetrcr45's Avatar
streetrcr45 streetrcr45 is offline
if there was a difference between the two would it be something that had to do with the compression ratio like with the B18
DIE TRYIN
FORGIVE BUT NEVER FORGET
Old 08-26-2003, 12:55 PM
94tegRS's Avatar
I figured it would be something like H22A1 and A2 if it were anything like that but its just my gues about the H22 and H22A. but im pretty sure the numbers are correct.
also I think it is 156 ft/lbs USDM and 161 ft/lbs JDM.
not sure about torque for the type S.
current
history:
Old 08-26-2003, 12:57 PM
93accordEX 93accordEX is offline
there is no h22, people just call it that. h22a is jdm. h22ax (x = a number) is usdm. but I think europe has the h22a2 something like that. and also theres the h22a7 which has 220hp and another one puts out 220hp but is just called h22a.
www.cb7tuner.com
Old 08-26-2003, 10:51 PM
Oh, i thought the h22 was an engine itself, and h22a was just like a beefier version, i must have gotten it mixed up with the h22a and type s. Is the type s much more pricewise than an h22a?
Old 08-26-2003, 10:55 PM
Also, i saw some japanese engine importer in a magazine, and it said something about an h23? I've never heard of this. Does anybody know what it comes from and if it will fit, because i know an h22a is already a very tight fit. Oh yeah, im talking about my 90 accord.
Old 08-27-2003, 12:24 AM
94tegRS's Avatar
its from a prelude SI, the S is the F22b2's which 94-97 accords have as well, amybe other years acords as well. the SI has the H23, and the H22a is in the vtec lude, and if the H22 will fit, so will the H23, but the H22 is beter IMO, tiny bit less torque but VTEC and more HP
current
history:
Old 08-27-2003, 07:03 PM
AKKORDINGLY SICK AKKORDINGLY SICK is offline
h23's are non vtec with a bit higher displacement and are bigger then the h22s, my friend tried to get a 23 in his 5th gen but it wouldnt clear hoodline, i think the dif is that the 23 has a bit better torque
my baby
Old 08-27-2003, 09:00 PM
Re: H22 vs H22a?
then he used the wrong mounts or something. it will fit perfectly fine.
www.cb7tuner.com
Old 08-28-2003, 01:19 AM
94tegRS's Avatar
did he swap from a auto to manual as well. I saw a 5 speed from a 5th gen civic sedan go into a 5th gen hatch that was auto, and of course you have to use the manual trans mount, but the one on the frame itself was different, so the engine sits higher on left side now, but the hodd just has a dent on the inner skeleton, from the dist mount plate on top.
current
history:
Old 08-28-2003, 08:33 PM
How much would it run me for an h22a swap and manual conversion, with parts and labor? Also, how much would just a manual conversion cost? Also, can i swap over all my f22 bolt ons to an h22?
What needs to be done to an H22a internally to make it boost safely? preludeguy017 JDM Motor & Parts info/chat 1 06-02-2010 01:28 AM
Euro-R H22 vs. JDM H22A Ravenscool JDM Motor & Parts info/chat 8 07-13-2004 11:41 PM
How To Build A H22/H22a dmitrys Accord/TSX/Accord Hybrid 7 12-17-2003 03:18 AM
H22a or us H22? kumyaras Engineering/ Technical 3 01-16-2003 04:12 PM
Diff between H22 and H22A super 96 accord Engineering/ Technical 6 03-10-2002 11:10 PM
