Old 08-25-2003, 10:46 AM
DSM-Mark's Avatar
DSM-Mark DSM-Mark is offline
Resin Copies
Did a search, but no luck.
Question for our resin casters (fotw, etc). How difficult would it be for somebody at home to make a resin copy of existing plastic parts? I was thinking of making resin copies of the engine in the R32 skyline (for personal use only). Would this be possible, or would you have to do each piece at a time? I'm a little clueless about the process involved in making a resin mold/cast. Is it simple - at home - stuff, or do you need a lot of special equipment?
Any help would be appreciated. Thanks.
I work slowly!
Old 08-25-2003, 11:18 AM
hirofkd's Avatar
hirofkd hirofkd is offline
I first saw how resin casting works at age 15, and by 16, I was selling my own kits. To me, resin casting wasn't so hard. It was just that the material was very expensive for that age.
You might want to start with a kit, which includes everything.
MicroMark has such a product for about $70, and there should be similar products elsewhere. It's cheaper than buying individually (extra shipping), and you don't miss anything to start.
Basic idea of casting is to make the master part, bury a half of it in clay, surround it with cardboard or lego block, pour silicone and wait, remove the clay, apply mold release wax, pour the other half, and ta-da, the mold is done.
Mold making takes one to two days, because each side takes about 6 hours. (Do before you go to bed, and one side is done next morning.)
Then, engrave the air release and resin flow channels on the mold, mix resin, pour it, and remove the part, when it's cured.
Resin hardens in 5 - 10 minutes.
I have a crappy step-by-step, which desperately needs update.
http://www.asahi-net.or.jp/~xr2h-fkd...mboxster04.htm
Hiroaki Fukuda
Old 08-25-2003, 11:38 AM
DSM-Mark's Avatar
Re: Resin Copies
Thanks!
I had no idea that was your site! I must have read most of that site all the way through at least once, and the 944 and 968 sections at least 3 times! Great work!
I work slowly!
Old 08-25-2003, 02:08 PM
pettercardoso's Avatar
pettercardoso pettercardoso is offline
Send a message via MSN to pettercardoso
If you want to make your own parts, check out alumilite's website or Smooth-On's . Hope this helps.
Pedro
Click the picture to check my progress thread:
Old 08-25-2003, 03:19 PM
Vric's Avatar
Vric Vric is offline
i was looking for this too.. but i only need to duplicate 2 1/16 brake pad, so a 70$ kit is too expensive yor only 2 small part
Old 08-25-2003, 04:02 PM
DSM-Mark's Avatar
Re: Resin Copies
I suppose that's why not many people do it... you'd have to sell a lot of units to recover your cost.
I work slowly!
Old 08-25-2003, 10:36 PM
008's Avatar
008 008 is offline
Re: Resin Copies
You can get "sampler kits" of resins pretty cheap, some companies may even give away free samples. You don't need much to copy brake pads. Some clay to depress the pad into and some resin to make the copy. The original clay mold can't be reused (you have to press it again) but for a few parts it works just fine.
-Ron
Old 08-26-2003, 12:40 AM
Jay! Jay! is offline
Horizontally Opposed
Hiro's hit the main point, but here's some great links, too...
http://www.automotiveforums.com/vbul...ad.php?t=79091
Hierarchy of Subaru:
(Click to see mine!)
Old 08-26-2003, 01:06 PM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
DMS-Mark, Careful planning when doing multiple pieces is a must. The actual process is easy enough. I suggest doing it in sub assemblies. Just keep in mind that once you make the mold or cast the part it has to come out so any undercuts are ill advised.
VRIC, if you want to send the pieces to me I will make a mold of your brake discs for $5, you pay shipping. PM me
Old 08-26-2003, 01:57 PM
Lambo003's Avatar
Lambo003 Lambo003 is offline
I can vouch for Smooth-On's quality and value.
It's all I use for resin casting and mold making.
Their starter kits start at $25. to $30. Their website will answer all your questions about this technique.
Duplicate Resin parts Casting Kit suggestions? smileygirlmel86 Car Modeling 9 12-09-2010 08:59 AM
can anyone make resin copies of parts for me? tpliquid Car Modeling 6 06-25-2008 09:48 PM
Resin copy of MK2 rallye & mk2 VR6 sylverman Completed Projects / Gallery 14 04-10-2008 08:58 PM
Copies of tires - NOT resin klutz_100 Car Modeling 7 02-16-2008 02:20 PM
My First Resin Copy Blowncivic1320 Car Modeling 13 06-18-2003 04:03 PM
