Old 08-24-2003, 11:51 AM
cudadrt cudadrt is offline
Pushrod Length
I am building a 351w/393 stroker based engine for my '709 mustang and I have shaved my heads .030 and using a full roller setup and want to know if I can use a stcok length pushrod or if I will have to have special ones made for it? Thanks for any info that can be provided!
Dwayne
Old 08-24-2003, 06:38 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Re: Pushrod Length
Dwayne
If the block was originally a roller block you should be able to use stock length pushrods. If it was not a stock roller block and you are using a retrofit cam or something of that nature you will need to measure for ya pushrods. Either way I would use a pushrod length measurer just to be sure. This will give you the exact length you need.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Pushrods-Purpose? DavidovSpeedWRC Camaro Discussions 28 11-24-2003 04:11 PM
yukon booster pushrod removal??? larry4242 Yukon 1 11-01-2003 08:55 AM
Pushrods Queenpin Corsica 1 10-08-2003 11:54 PM
Exhaust Manifold Length Vs. Header Length lil_schmitts Prelude 3 09-15-2003 05:46 PM
Pushrod vs DOHC Neutrino Engineering/ Technical 39 06-20-2003 05:21 PM
