View Poll Results: 6G72 in a Galant GSX if it was possible , would you do it?
Hell yeah , sounds badass........!!! 2 66.67%
No way , too much trouble 0 0%
We would suggest you have your head examined........... 1 33.33%
Voters: 3. You may not vote on this poll
Old 08-24-2003, 05:55 AM
RockinWRX RockinWRX is offline
Send a message via AIM to RockinWRX
6G72 swap into a Galant GSX.....................
I hear tales of a swap like this being done , putting the 3000GT/Stealth motor into a Galant GSX ( AWD nonturbo ) , but I can't find any details. Anyone care to point me in the right direction?
I'm basically tired of the whole idea of converting this car to turbo and doing up the 4G63 the way countless other DSM'ers before me have done it. I wanna do something a bit different , which is why I'm considering this swap. Besides , I'm pretty sure the 3000GT/Stealth drivetrain is a lot more bulletproof than the DSM cars ?
'90 Galant GSX , AWD , 5spd. Waiting on an engine swap.
'03 WRX wagon , AWD , 5spd. Waiting on a paycheck.
Old 08-24-2003, 07:06 PM
ROB3000GTVR4's Avatar
ROB3000GTVR4 ROB3000GTVR4 is offline
AF Premium User
Why in the hell would u want to do that.that sound kind of why not just buy a 3000 or a STEALTH
Old 08-24-2003, 07:26 PM
Re: 6G72 swap into a Galant GSX.....................
Lots of reasons. For one , the car I'm using is a lot lighter at only 3000 lbs. And if it is done , there only a very few like it in the country. Try thinking outside your small world for a change.
Old 08-24-2003, 07:40 PM
AF Premium User
Re: Re: 6G72 swap into a Galant GSX.....................
if u did put a 3000 or STEALTH motor in your car it still won't be faster thin a vr4 or STEALTH TT
Old 08-24-2003, 07:42 PM
blasian_man's Avatar
blasian_man blasian_man is offline
why not? is there something wrong with the way galants put down power that wouldn't make it faster that a 3000/stealth
oh never mind you said tt
Old 08-24-2003, 07:51 PM
AF Premium User
Originally Posted by blasian_man
why not? is there something wrong with the way galants put down power that wouldn't make it faster that a 3000/stealth?
im not trying to knocking your galant.there just a a big diffrents in hp 222vs300or320 & 4wd vs 2wd. That why i said just buy a vr4 or stealth tt.
Old 08-24-2003, 08:52 PM
Um , the Galant is AWD , and I plan on swapping the entire drivetrain from a 3000GT Twin-turbo /Stealth R/T TT into it , as well as the ECU and wiring and whatever else is necessary. Basically , it should fit. And I shouldn't have issues with frame fabrication , since the tunnel for the driveshaft is already in place , the gas tank shouldn't need to be moved , and the rear subframe is almost the same , except for the AWS parts , which I plan on removing anyway. I'm just asking If anyone's done this before , and what I need to watch out for , but If I have to go it alone , thats fine too.
Old 08-24-2003, 08:57 PM
AF Premium User
Re: Re: Re: 6G72 swap into a Galant GSX.....................
my bad didn't know it was 4wd but good luck
Old 08-24-2003, 09:32 PM
Re: Re: Re: Re: 6G72 swap into a Galant GSX.....................
Duuuuuude , I specified AWD in the first post , and read the sig. That's the car that's gonna be modded. I'd still appreciate any relevant information.
Old 09-04-2003, 11:56 PM
Team Ducktape Team Ducktape is offline
Basically , it should fit. And I shouldn't have issues with frame fabrication , since the tunnel for the driveshaft is already in place , the gas tank shouldn't need to be moved , and the rear subframe is almost the same , except for the AWS parts , which I plan on removing anyway. :
I thought you had a GSX not a vr-4? So you don't have the AWS to remove.......
Old 09-05-2003, 12:16 AM
No , I meant the AWS from the 3000GT diff , which I will have to use , since I know the stock GSX diff will not take the pressure.
Old 09-05-2003, 04:43 AM
Re: Re: Re: Re: Re: 6G72 swap into a Galant GSX.....................
OIC, got it now..... but;
Pressure? And what do you mean by this? The 3 bolt that it has can hold plenty of power to the right driver. And if you wanted to swap a 4bolt in you would be capable of holding even more. I like that fact you want something different, but if you want something rare you AND OR different you should just buy a Galant vr-4, rather than messsing with the headaches.......... Two years they entered the states, 1991 and 1992. 2 thousand of them in 1991 and only 1 thousand in 1992. So less than 3 thousand actally on the road in the USA.......
Old 09-05-2003, 05:24 AM
Re: Re: Re: Re: Re: Re: 6G72 swap into a Galant GSX.....................
Pressure? Sorry , meant torque. And most every DSM racer upgrades to the 4-bolt LSD diff that was in the 92 cars. Lotta guys here have broken their 3-bolts , so I'll go with that. Of course , the driver may be at fault , as you say , but I'd feel safer with the 4-bolt diff. I may not use the 3000GT diff , because of the AWS , but I don't know how different the driveshafts are between the much smaller lighter DSM cars and the 3000GT. I'm also considering just doing a straight 4G63T swap , as a few others have done. It'll still be a fun fast car either way.
6g72 swap with 6g72 tt nyckreyna 3000GT/Stealth 2 04-23-2010 05:03 PM
galant front end swap with lancer tedkre48 Galant 0 03-01-2010 10:39 PM
93 D16Z6 swap into 91 CRX SI, Need help riptech7 How-To's and Walk-Through's 2 01-08-2010 08:48 PM
1990 Galant GSX/ 1991 Galant VR4 project Sleepr awd Members Project Cars 31 01-04-2008 06:45 PM
Galant GSX, Can it be a VR4,should I buy a gsx? T4T2T Galant 5 06-22-2004 09:35 PM
