Old 08-23-2003, 10:06 AM
91dx 91dx is offline
AF Cutter
might of found my problem.. not sure..
well some of you know how my car is running bad and stuff. I was taking off the spark plug cover an wires to see if my plugs were gapped an stuff. I took off that cover and they were all in oil. I took off the plug wires and pulled them up and they dripped oil, then I pulled up the plugs and they were submerged in oil it appeared because the shit ran off my plugs.. anyway so here's what I did. I decided to get the following:
AC RACE CAM-SEALS
head gasket set
crank case gasket
place racing front crossmember w/ tranny mount
AEM CAI
apr head studs
65mm bullfrog gsr ported throttle body
aem fuel rail
walbro 255lph
B&M comandflow fpr
valve job, head milled/ported and polished, and ported intake
maybe ---> valves
maybe --->springs/retainers
I figured while I had my head off I might as well start replacing shit that I don't want to do again.. anyway you guys think this will fix my problem cause I had valve seals leaking and a nasty head gasket leak as well.
Old 08-23-2003, 10:16 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
might wanna change your piston rings too.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 08-23-2003, 10:19 AM
AF Cutter
Re: might of found my problem.. not sure..
I might as well get the whole piston setup then don't you think? I have some extra money so if there's anything I need PLEASE suggest it guys! thanks!
Old 08-23-2003, 10:37 AM
SiZ's Avatar
SiZ SiZ is offline
Man, you have no use for race cam-seals, or the head studs, or the fuel pump, fuel rail, an fpr. Also, valves and valvesprings - useless without cams.
"The nympho of info, I'm fuckin' what ya heard"
Old 08-23-2003, 02:54 PM
AF Cutter
make a list of parts under like 2000 dollars of what you would get if you were me then siz hah and i'll check it out. Later im going to do a nitrous setup and possibly supercharger so this stuff I have down wont apply to that shit later ???
Old 08-23-2003, 09:09 PM
BullShifter's Avatar
The spark plug tubes are made of 2 pieces with a rubber grommet/seal in between the 2. Replace the rubbers & No more leaks. The throttle body, head work, & intake work will be nice! Might as well upgrade the cam(s) while your at it
Old 08-23-2003, 09:11 PM
crxlvr's Avatar
for 2g, id get new cams, pistons, and rods all for turbo app if your gonna do it soon.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
front brake problems...not sure whats going on phuz S60 2 01-20-2006 06:41 AM
clutch or tranny problem not sure please help! ounderoatho General Discussion 1 12-16-2005 08:10 AM
Gas problems, not sure if it's a problem or normal? malibu81racer S-10 1 10-03-2005 11:08 AM
2005 Toyota Transmission and Idle Problem? Not Sure. GABBQMAN Tundra 1 01-19-2005 10:06 AM
Auxiliary Fan Motor Problem - Not Sure minbel Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 01-14-2005 06:02 AM
