Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 01-13-2005, 01:46 PM
minbel minbel is offline
Send a message via MSN to minbel
Auxiliary Fan Motor Problem - Not Sure
I have a 2001 Max SE 20th Anniversary edition and lately I started noticing that when I turn the engine off I hear the stuttering noise.
At first I thought my car was dying on me but I pinpointed the problem to one of the cooling system fans. This morning it got worse - it vibrates and stuttering noise won't stop.
Does anyone know if that's a problem with an auxiliary fan motor or maybe propeller itself has shifted? How much it will approximately cost to change the motor or is it worth trying and checking myself?
Any help would be appreciated! Thanks!
Old 01-14-2005, 12:28 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: Auxiliary Fan Motor Problem - Not Sure
It should go on only in long idle, hard drive or very hot weather.
See if its not loose, propeller is tight (similar tightness to the non noisy one), nothing loose and/or leaning on its rubber pad 'insulated' structure. Replace or just take connector off. With one fan you can get life through, not maybe on Paris-Dakar desert rally...
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 01-14-2005, 06:02 AM
Re: Re: Auxiliary Fan Motor Problem - Not Sure
Thanks a lot! That's what I was going to ask this morning - if I can disconnect it until I get the part and use just one fan... Appreciate your help!
