Old 08-20-2003, 06:59 PM
tyrell92 tyrell92 is offline
my rpm gauge jumps up and down.
1995 honda accord lx. my rpm needle starts to drop and rise rapidly while car is not moving. it goes crazy while on the highway and car starts to pull back and forth. anyone had this problem?
Old 10-31-2004, 06:56 PM
bowerskd bowerskd is offline
Re: my rpm gauge jumps up and down.
My 95 ex does something similar. When I am driving around it goes up for no reason and no idiot lights come on. Any help.
Old 11-02-2004, 05:27 PM
phantastic1 phantastic1 is offline
first off....check for any vacuum leaks. secondly....make sure there's no air in your cooling system. air in the cooling system could also cause the symptoms you have.
Old 11-03-2004, 03:57 PM
blacknight's Avatar
blacknight blacknight is offline
Check the vacuum lines. Some may be damaged or clogged. Also check your PCV Valve. And if your plugs & wires are old, it wouldn't hurt to change them also
what's that red button on your steering wheel.......OOOHHH MMMYYY GODDDD :22yikes:
Old 11-28-2004, 04:21 PM
korpri korpri is offline
Re: Re: my rpm gauge jumps up and down.
how do you check for air in the cooling unit? what do we do if air is trapped in the cooling system. is there any way i can flush it out?
Old 11-29-2004, 11:36 AM
scubawrstlr's Avatar
scubawrstlr scubawrstlr is offline
Send a message via AIM to scubawrstlr Send a message via MSN to scubawrstlr Send a message via Yahoo to scubawrstlr
I don't have any surging, but when I'm in 4th gear on the highway. Sometimes it sticks at like 3000-3500 then it gets up to 4000 then we i let off the gas it sticks at 4000 for a while unless i tap it. No problem, just bugs me sometimes.
I've only just begun...
Old 11-29-2004, 11:47 AM
AccordCodger AccordCodger is offline
C'mon, scubawrstlr, you should know better than to hijack someone else's thread (your issue is clearly different).
Old 11-30-2004, 09:29 PM
LILT23 LILT23 is offline
clean the fast idle valve just did it to mine today and it's gone it is to the right of the ecu on the front of the intake.. take off and open top take everything out of it and scub it real good and put back together and back on the car and it's gone!!
Old 11-30-2004, 11:17 PM
Sorry, Codger, thought it was close enough. Don't hate me, lol.
Old 12-01-2004, 06:47 AM
I don't hate you, man (and, by the way, I suggest some WD-40 on your throttle linkage/cables.)
Old 12-01-2004, 11:43 AM
can do
Windstar rpms going up and down at idle Christiemarilynn Windstar 1 12-05-2008 08:38 AM
2000 rpm goes up and down while slowing down. hckybrownie31 Monte Carlo 3 08-29-2007 03:15 PM
Engine RPMs go Up and Down - Urgent please Moe Arif '88 - '91 Civic | CRX | Wagon | Shuttlee 31 07-23-2007 04:50 PM
RPM moves up and down at full speed? vis_inc Blazer 0 08-08-2006 04:32 PM
sport trac shaking some,rpms go up and down a little, black smoke from exhaust? mdlott Explorer | Explorer Sport Trac 0 02-15-2006 09:36 AM
