Old 07-09-2007, 10:44 AM
Moe Arif Moe Arif is offline
Engine RPMs go Up and Down - Urgent please
89 Honda Civic 3 door hatch 1.6 lit. - Only when car is driven for 20 minutes or so, and kept either in Park or neutral, the RPMs go high and low, in a repititive fashion. Just like the car is in park mode and someone is accelerating and releasing in a cyclic fashion.
This started to happen about 3 weeks ago. Otherwise the car drives very well.
Old 07-09-2007, 12:58 PM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
Re: Engine RPMs go Up and Down - Urgent please
what rpm is it movin up and down thru..when idling mine sometimes moves about 100-200 up or down. i kno its from a vacuum leak somewhere..i just need to find it
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 07-09-2007, 01:03 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Sounds like a vacuum leak, or your EACV. Do a search and youll learn tons as this is a common problem on these cars.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 07-09-2007, 01:37 PM
Between 1200 and 1300 RPM. Normal is 900 RPM.
When it happens, opening the hood seems to be a bit hotter than before (not sure). Thought it was a vacume leak somewhere. Is there a test I can do to confirm.
My mechanic friend says it is fuel related. Mine is automatic, it simply revs up, otherwise (if manual) it would have stalled.
ANY suggestions as to how I can confirm between fuel and vaccum issue.
Thanks.
Old 07-09-2007, 03:27 PM
FrodoGT's Avatar
Well since its an auto when its in drive there is a load on the engine and it wont surge up and down like if it were just idling. Are you throwing any check engine lights? look under the passenger side carpet and look in the little hole on the ecu, are there any blinking lights? if so, how many? count the blinks, if there is more than one code it will pause in between, then repeat.
Current project:
Rio Red 91 hatch.
Old 07-09-2007, 09:05 PM
viper-blue's Avatar
viper-blue viper-blue is offline
like frodo said check for codes...if the system can't maintain proper fuel pressure it would cause the syptoms you have, but these cars have fuel pumps that just won't die...any fuel odor around the car?
89 crx SI - spoiler, custom viper blue paint job, Z6 just completed, stock 14's with a 3 inch drop, sidemarkers, and the stereo
"my crx is like my woman: don't like anyone touching her, or driving her but me!"
Old 07-11-2007, 08:04 AM
Re: Engine RPMs go Up and Down - UPDATE
My mechanic friend did some tests and said its my Fuel Injectors gone bad. They are costly @ $400. Mine has two of them. Dont have this kind of money. Any advise.
Should I take a second opinion?
Old 07-11-2007, 09:50 AM
FrodoGT's Avatar
What kind of freaking solid gold injectors is he talking about?! thats crap..if you think its your injectors go pull a couple from the junkyard and call it a day, they arent hard to install.
Current project:
Rio Red 91 hatch.
Old 07-11-2007, 11:27 AM
That's good to know FrodoGT. Roughly what would be the cost of a FI be, used and new.
Sounds like it may be affordable to me, in which case I will try installing it myself (if you say it not too hard) - Have any instructions? diagrams?
Thanks.
Old 07-11-2007, 01:48 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
Doe sit do it whwen the car is cold or only when it's warm ? if it only does it when it's warm it could be cause by a dirty FITV (fast Idle throttle valve) use take it appart, and wash it with break cleaner.
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 07-11-2007, 04:26 PM
FrodoGT's Avatar
The FITV is for cold idle...the EACV or IACV (same part) is for warm idle. Also, d series dont have a FITV..b series do
Have you checked for ecu trouble codes yet?
Current project:
Rio Red 91 hatch.
Old 07-11-2007, 08:36 PM
viper-blue's Avatar
if the mechanic said it was injectors I would definately just use junkyard ones. You don't wanna spend all that money to find out that the injector wasn't the problem. It sounds doubtful if the problem only happens when the engine warms up. You should check the codes yourself. Do a search on checking for engine codes. Its easy. The mechanic might be trying to take advantage of you at that price, lol. Sounds like dealership prices. Replacing them is self explanatory if you just look under the hood
Old 07-12-2007, 12:00 AM
yeah you just disconnect your fuel line from the pump and leave it attched to the fuel rail. then unbolt the fuel rail and pop out your injectors. shouldnt even take you an hour to fix. you could try cleaning them but the car is old so you might as well just buy some new ones off of ebay or junkyard them..pm me and ill send you the shop manual if you dont have one
where you been kunundrum?? havent seen you on here in ages
Old 07-12-2007, 01:20 AM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
His car is dpfi, so no fuel rail. Before even replacing the injectors (they rarely ever go bad on these cars) do as Frodo said, his advice is gold; even better than your mechanics'. Clean your IACV, its not hard at all, take it off, get some carb cleaner and soak it clean. 30 mins tops and your problem is likely to go away, try it out before doing some costly repair.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 07-12-2007, 08:30 PM
my bad lol
