Go Back   Automotive Forums Car Chat > Plymouth > Acclaim
Old 08-20-2003, 04:08 PM
eddie32818 eddie32818 is offline
Unhappy Help with Airbag Warning Light -- No A.C.
I hope someone can help me with this:
Recently, my Airbag warning light has been coming on when I start my car, momentarily goes off for a few seconds, then returns at a steady illumination. Meanwhile, my A.C./Heater is completely non-functional (no blower motor) and the rear defroster is rendered inoperable. Fusebox's fuses all checked out OK.
Maybe the warning light is on the same electrical circuit as the blower component, or on the same breaker, fuselinked wire, electronic relay, if applicable.
I'm not sure if the airbag should be "dealer" serviced (as a last resort) or if maybe there is something else that can be done before I consider the last resort.
Any suggestions would be most appreciated -- Thanks.
Old 05-16-2004, 08:38 PM
crash8168's Avatar
crash8168 crash8168 is offline
Re: Help with Airbag Warning Light -- No A.C.
if all those problems happened at the same time, replace the ignition switch. the electrical part of it.
Help with Airbag light Diznblond Alero 9 09-27-2006 01:44 PM
03 Jetta Airbag Warning Light 56pickup502 '97 - '03 9 11-06-2005 10:35 AM
airbag warning light lee100 Yukon 2 01-02-2005 04:51 PM
need help with dash warning light william38 Off-Topic 1 08-05-2004 05:56 PM
2002 Pontiac GA SE airbag warning light ancient1 Grand AM 0 04-15-2004 07:34 PM
