Old 09-26-2006, 09:18 AM
Diznblond Diznblond is offline
Help with Airbag light
I just replaces my airbag in my alero, because the horn was bad, and the airbag light keep blinking intermitently while I drive down the road, then goes off. How do I reset this, is it like the oil change light
Old 09-26-2006, 09:39 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Help with Airbag light
Did you scan the car for DTC's before you replaced the airbags?
Should hav been a code stored, and it will probly need reset with a scan tool.
And Welcome to AF !
1999 Grand Am SS 3.4 OHV
Old 09-26-2006, 02:11 PM
Never heard of DTC's to be honest, what about if I put the old airbag back in, I still have that, would that fix the problems?
Old 09-26-2006, 02:46 PM
No !
The DTC is Diagnostic trouble codes.
You need a scanning tool to reset that air bag light most likly.
Could also be your ABS module that bad, its under the passenger seat I think.
Tho, the ABS mod will need to be checked by a stealership.
Old 09-26-2006, 03:14 PM
Smile Re: Help with Airbag light
Thank you for the help
Old 09-26-2006, 03:16 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: Help with Airbag light
Originally Posted by xeroinfinity
No !
You mean the sirs module, right, anyway a full function Snap-On mt 2500 scanner can check sirs codes also.
Old 09-26-2006, 08:51 PM
I didnt know that max, thankx !
Old 09-26-2006, 11:21 PM
JTrujillo86 JTrujillo86 is offline
Before you go replacing parts in your car, have it scanned as mentioned before. Just because the airbag light is on doesn't mean the airbag itself is bad. Sensors or wiring are most likely to blame for the issue.
- Jeremy
Old 09-27-2006, 10:05 AM
BNaylor's Avatar
BNaylor BNaylor is offline
OK guys, lets get the terminology straight. SDM module. Service and Diagnostics Module.
Carry on.
Timeslip 08/12/06
AF Community Guidelines
Old 09-27-2006, 01:44 PM
Carry on.
Now dont go and get all technical on us Bob
