Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 08-19-2003, 08:39 PM
gfm gfm is offline
differential seals leaking
I Just Got A 1993 4wd Explorer, I Think My Front Diffential Seals Are Leaking. Any And All Advice Or Experiences Would Be Appr. Like Cost Of Repairs Etc. SOMETHING I CAN FIX MYSELF OR A DETAILED WEBSITE ON REPAIRS
Old 12-14-2003, 08:00 AM
Urbanistic Urbanistic is offline
Send a message via ICQ to Urbanistic Send a message via AIM to Urbanistic Send a message via MSN to Urbanistic Send a message via Yahoo to Urbanistic
Re: differential seals leaking
I am looking for information on this problem as well. I have a 1993 Limited and the front differential will leak down to about 1" below the fill-hole (where the fluid should be equal to the edge of the hole to indicate proper level).
I have cleaned and inspected aroung the interior part of the frame where the differential case cover fits inside. I am able to see the red gasket material filled all around.
I do see visible indications of leakage occuring near the axle... as if the fluid is leaking from the seating seal that is around the axle and at the axles entrance to the differential case.
I propose that this would be the cause of the low fluid level, leakage when filled to specifications.
Gfm, does your vehicle still leak? And if so, are you able to see evidence of leakage aroung the front-right axle?
95 Suburban front differential axle seal leak jjwg3 C/K 10 12-07-2010 12:15 PM
Rear differential Seal Leak? stantony1 Rodeo | Passport | MU 2 09-20-2010 11:22 AM
How hard is a rear differential pinion seal to replace? mkenyon2 Modifications/How To 3 03-16-2010 10:58 AM
Rear differential CV axle seals leaking bochnak Explorer | Explorer Sport Trac 4 05-03-2007 06:55 AM
Leaking Front Differential Seals kaskillah C/K 1 10-15-2003 10:04 AM
