Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 05-02-2007, 07:55 AM
bochnak bochnak is offline
Rear differential CV axle seals leaking
02’ Explorer XLT V6 2wd.
The rear differential CV axle seals are leaking and need to be replaced. Is this a fairly simple repair? I plan on picking up a manual from the library.
Thanks,
Matt
Old 05-02-2007, 12:26 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Rear differential CV axle seals leaking
Is it the axle seals in the differential that are leaking, or the rubber boots around the CV joints?
-Rod
Old 05-02-2007, 12:35 PM
-Rod
Seals in the differential, not the rubber boots around the CV joints.
Old 05-02-2007, 05:15 PM
shorod's Avatar
SHO No Mo
Oddly enough, I can find the procedure for changing the rear halfshafts, with special tools called out to avoid damaging the rear axle seals. I find a procedure to replace the pinion seal. But I find nothing in the factory service manual for replacing the axle seals.
-Rod
Old 05-03-2007, 06:55 AM
-Rod
Thanks Rod,
I checked out a manual from the library last night. CV axle diff. seals seem straight forward. Replacing the pinion seal is a bit more involved as you need to have proper preload when reinstalling.
I have a seal puller that is found in any auto parts store.
