Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 08-17-2003, 12:38 PM
WillKool1080 WillKool1080 is offline
Supercharger: opinions/advice
I have decided to go with a supercharger instead of a turbo. Someone told me I would need twin turbos, something about the engine being in a V configuration, is this true?
Anyways I have a 1996 with a 3.1L engine, what superchargers are compatible with my car?
Which would be better, a turbo or a supercharger, and which would be easier to find.
Thanks for your input,
William
Old 08-17-2003, 04:42 PM
DragginWagon DragginWagon is offline
Send a message via AIM to DragginWagon Send a message via Yahoo to DragginWagon
With a turbo setup, you would be much better off going with twin turbos. If you wanna save $$, hit up a junkyard for an old Chrysler Turbo LeBaron or other Chrysler Turbo 4-cyl car...the whole car can be had for about $75 if you're lucky - but you really just need the turbo and the exhaust manifold. Check out Omni-Turbo for info on these cars and how to make a custom turbo setup on the cheap. You're gonna need someone with welding skills, and some creativity, but it's a really cheap way to get started on turbos. Later you can upgrade to larger Mitsu turbos...I considered turbocharging my D-Wagon, but it has 10:1 compression, so that's a little unrealistic. Good luck!
I'm sportin new Infinity's out back with my custom install. w00t w00t!
I don't care how mortgages you take out for it, nobody will ever have a 600whp Diamante.
Old 09-03-2003, 11:42 AM
RacerX83 RacerX83 is offline
Re: Supercharger: opinions/advice
I have a 1995 3.1 and I've already went down the turbo/supercharger road. It is possible to do what you want, but without a lot of custom engine components you wont be able to run a boost level worth having. I know a couple of places that can get you fabricated parts but low compression pistons alone will run you around a thousand dollars. I recomend getting power from the engine itself. The 3.1 V6 has a lot of untapped power and for as much as you'll spend (time and money) getting a turbo or supercharger for your car, you could do a lot with the engine, trans., suspension, etc. If you've got the money then go for it, but I've found it's a lot easier to tune horsepower out of the engine than force it out with a turbo.
B series project need opinions/advice Darc Tangent Let's get Technical! 10 10-05-2004 01:54 AM
Del Sol project nedd opinions/advice Darc Tangent '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 18 01-26-2004 09:32 AM
wheels, opinions/advice please! Miataracer Tires and Wheels 11 01-02-2004 12:21 PM
94 delSol who needs a body kit. Opinions? Advice? delSol86 Exterior | bodykits | Lighting 1 10-09-2003 04:07 PM
