Old 08-16-2003, 03:56 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
code 3
im getting a code 3 absolute manifold pressure, can anyone help me with this? i feel dumb asking this question i know i seen this question before but i searched and came up with nothing, help is appreciated
2002 Acura TL Type S
1991 Honda Crx Si
Old 08-16-2003, 11:01 PM
BullShifter's Avatar
Code #3: Most likely an electrical problem in the MAP sensor
Start engine & warm to operating temp & check MAP sensor connections
Pull hazard fuse from under hood
Re-install fuse
Start engine & check for re-coding
It could be a wiring problem, bad map sensor, or bad ECU.
Old 08-16-2003, 11:54 PM
i have a feeling its the ecu, i dunno when it happends theres a funky ass smell, oh well i got me a new job that pays good, might just convert to obd1.....
1991 Honda Crx Si
Old 08-17-2003, 01:27 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
do like jackass said, pull the hazard fuse for 10 sec and warm the engien back up and see if it still throws the code, make sure the cooling fan comes on to let u know its all warmed up.
if u still get the code, turn the car off and pull the connector from the map snesor and turn the igniton on, measure the voltage between the yell/red and the ground, there should be 5volts. if there is 5 volts then measure the volts between the yel/red and grn/wht, there should be 5 volts. if there is 5 volts then measure the voltage between the white and grn/wht wires, there should be 5 volts. if there is 5 volts turn the ignition off and reconnect the connector. then turn the ignition back on and check the voltage between c11 and c14 on the ecu, there should be 3volts, reminder that the ecu needs to be hooked up so go fromt eh wiring harness side to measure. if there isnt 3 volts replace the map sensor, if there is get a good ecu
that should take care of it. if any of the steps before the ecu fail, then theres an open circuit somewhere, let me know what happens so i can tell u exactly to where the opne circuit goes to on the ecu
Team Lonely Drivers
1993 Acura integra Stereo Code Omega-Factor Interior | Audio | Security 1 03-25-2009 07:08 PM
'98 Blazer - Codes, codes, codes! MAF & O2 LAN2UNOW Problem Diagnosis 3 03-02-2008 08:56 PM
codes,codes,codes vdubdad Beetle - New/New Beetle Convertible 0 10-22-2007 08:33 PM
Codes, codes, codes.... alkemist Riviera 7 06-19-2006 06:52 AM
Codes, Codes, CODES!!! patrickkdunn Contour 8 05-01-2004 04:31 PM
