Old 08-16-2003, 08:14 AM
88hondaowner 88hondaowner is offline
Banned
Send a message via MSN to 88hondaowner Send a message via Yahoo to 88hondaowner
What all do I need?
Ok im wanting to do a b16 swap in my crx. I know some of what i need can you guys help me out with the other stuff i dont know?
Engine-B16a
ECU-?? (which one do I use)
Tranny-?? (which one do i use)
Motor mounts-Hasport
Axles-?? (which ones do i use)
Shift linkage-??(which one do i use)
What else do I need?
Thanks for the help!
Old 08-16-2003, 08:40 AM
91civicDXdude's Avatar
Re: What all do I need?
Engine-B16a
I know people hate it when they dont get any reply so here goes.
1. b16a, good choice.
2. ECU - PR3, PW0, whichever OBD0 VTEC ECU comes with the swap
3. tranny should come with the swap, but any cable B series will work
4. Hasport are good, if you are looking for a little bit cheaper mounts, I recommend HCP
5. Axles - Depending on which intermediate shaft you use, go with the matching axles for the tranny.
6. Many companies, HASPORT, HCP, etc. sell adjustable shift linkages, I personally cut the B18A1 linkages and welded them back together shorter.
Old 08-16-2003, 08:46 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
any b series cable tranny is easy to use, but there are hydro-to-cable conversion kits so you can use like a type r LSD tranny if u wanted.
hcp of hasport have the best mounts, get a 4 mount kit if possible
use a pr3 ecu if you can, they are better than the PW0.
axles, you might have to "build" them check out www.hasport.com they have a nice tech article bout the axels.
hasport place racing, and hcp all sell shift linkagaes, you can modify your own, or an 90-93 integra unit to comply.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 08-16-2003, 10:00 AM
jNYCe5 jNYCe5 is offline
Send a message via AIM to jNYCe5
you will also need to use the 90-93 integra rear bracket. if you have an si, you will have to add four wires to your harness for the vtec, oil pressure, knock and 2nd 02.
if you have a dx. you will have to upgrade to multi-point injection.
try doing some research as well. there are plenty of websites and alot of information on this board about this very same question.Search is your friend
Julian
What all do I need? 88hondaowner '88 - '91 Civic | CRX | Wagon | Shuttlee 3 07-04-2003 11:50 AM
ZC, what all do you need for sure?!??! soulkeeper '88 - '91 Civic | CRX | Wagon | Shuttlee 19 03-15-2003 12:45 PM
What Is Needed To Get B16a1 Into High 13's All Motor? UMREX '71-'87 Civic | CRX 14 03-11-2002 12:37 AM
What all is needed? 1995HondaCivic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 02-13-2002 11:38 PM
