Old 07-04-2003, 11:33 AM
88hondaowner 88hondaowner is offline
Banned
Send a message via MSN to 88hondaowner Send a message via Yahoo to 88hondaowner
Question What all do I need?
Ok are coilovers the same as springs? Or do I have to buy springs and coilovers? I have seen people posting that they have Skunk 2 Coilovers with Eibach springs???? I need some help.
Old 07-04-2003, 11:44 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
springs are set at an inch drop or whatever thier drop is.....coil overs are adjustable like 0 to 4 inches of drop..... hope this helps...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 07-04-2003, 11:45 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
last time i checked, springs and coilovers were pretty much the same thing, except arent coilovers flat on each end? and springs just end at a certain length?
i dunno, just a guess, then again i am pretty
Old 07-04-2003, 11:50 AM
yeha22 yeha22 is offline
coil-overs are not the same thing as springs. a spring is just that, a spring. but a true coil-over is a spring and shock combo. they are engineered to work together. the advantage of a true coil-over is that you have the proper damping for the spring you are using. usually, if you just throw a set of springs on your car, you will blow through your shocks (the dampers) quickly because they do not offer the proper compression and rebound resistance. hope this helps.
What all do I need? 88hondaowner '88 - '91 Civic | CRX | Wagon | Shuttlee 3 08-16-2003 10:00 AM
ZC, what all do you need for sure?!??! soulkeeper '88 - '91 Civic | CRX | Wagon | Shuttlee 19 03-15-2003 12:45 PM
What Is Needed To Get B16a1 Into High 13's All Motor? UMREX '71-'87 Civic | CRX 14 03-11-2002 12:37 AM
What all is needed? 1995HondaCivic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 02-13-2002 11:38 PM
