Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 08-16-2003, 12:50 AM
Revolution 7o7 Revolution 7o7 is offline
Axle Question ?????!!!!! HELP ME PLEASE
Ok heres the deal My Jspec 94 lude is a lil under the weather right now im tryin to change the clutch and i cant seem to get the drivers side axle bolt loose ive broken two breaker bars and im lost .... is there a way to remove the axle without removing the axle bolt .... or do u have any advice on getting the bolt off .... Heres what ive tried .....wd40 with a breaker bar and a 3 foot pipe over top for more leverage any ideas please please help ??????? thanx guys and gals !
Old 08-17-2003, 01:40 AM
bambam2000 bambam2000 is offline
I just took down my tranny and what i did I took to whole axel with the center shaft or smething like that off just take the tree bolts that are holding it then when you have it out side hit it with a hammer.
Old 08-17-2003, 10:54 AM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
air impact wrench.
Old 08-17-2003, 07:50 PM
thank you guys for the advice but im stuck again on the same drivers side how exactly does the axle come out of the tranny its not like the passenger side im confused ...... please help guys thanx again
Old 08-18-2003, 06:02 AM
drift's Avatar
Re: Axle Question ?????!!!!! HELP ME PLEASE
it's a ring clip that holds the stub axle to the diff. just use a flat head screwdriver to pry the stub axle from the diff housing.
Old 08-19-2003, 04:52 PM
hye i got the axle out of the way and all of the tranny bolts are loose but tranny wont come off anymore advice guys ??
Old 08-20-2003, 02:27 PM
drift's Avatar
sounds like you're doing a tranny drop/clutch replacement without a manual.
get a manual.
Old 08-20-2003, 06:22 PM
Yeh i have a helms manual and it seems kinda vague but oh well i got it off and changed .... (had to pry it off with a screwdriver ) but that kinda stuff happens after 5 days of Grease Beer and more greese she is done !!! Drift thanx for ur help and everyone else's advice i apreciate it a lot ... but if u want to check out my car and give me some tips just click on the link below ! thanx again u all
My 94 J-spec
Stuck Inner CV Axle - 93 MX6 - Help Please! ziggy414 MX-6 0 11-29-2009 09:24 PM
driver axle install help please. cmjrbking123 '88 - '91 Civic | CRX | Wagon | Shuttlee 9 08-07-2007 06:40 PM
Drive axle? Need help please! klone420 How-To's and Walk-Through's 6 03-03-2005 07:21 AM
Stupid Brake caliper wrench question... help, please dmellano Grand AM 6 01-22-2005 09:59 PM
99 civic swap question!!!!!!!HELP PLEASE crabby760 Engineering/ Technical 1 08-20-2003 10:28 PM
