Old 08-15-2003, 11:12 PM
edeibert edeibert is offline
Angry 2001 tahoe not going into Reverse or OD
I have a problem with my 2001 Tahoe. When i put it into reverse the tranny will not engage. I can get it into drive but it will only shift through 1, 2, and 3 but not OD. Can't back out of the garage and have to go to work tonight. Any ideas??
Old 12-07-2003, 03:15 PM
Ter Ter is offline
Re: 2001 tahoe not going into Reverse or OD
I have exactly the same problem with my 2001 Tahoe, with only 34,265 miles. Also a ABS pump constantly running.
Have you resolved the problem ? What was wrong ? Please help.
Old 12-07-2003, 03:30 PM
JD68 JD68 is offline
I have believe i have the same problem as you,(see thread below yours) i have found a Tech Service Bullietin: 00-07-30-022 NOV 00 A/T - 4L60E No Reverse, 2nd, or 4th Gears. but i dont have access to it for the specifics, this happened to me last night, but from what i have found it might be the Sun-shell gear failing, i hope its not cause this means a transmission rebuild. does you car shift hard from 1st to next gear when in D?
Old 12-07-2003, 04:35 PM
jonathan_suan jonathan_suan is offline
I had the same problem - no reverse and lack of a couple other gears on a 99 Tahoe with less than 50k miles. The cause was a broken/defective sun shell gear found during the transmission rebuild.
2001 Accent not going into Overdrive gfolkins Accent | Verna 1 12-12-2007 10:18 PM
Transmission not going into reverse misty creek Savana 1 12-11-2007 03:14 PM
88 Cavalier not going into reverse? Nurv Cavalier Problem Diagnosis 4 09-18-2005 01:13 AM
R350 will not go into reverse John D Ram Van 0 04-19-2005 01:16 PM
2000 neon will not go into reverse podboy3 2nd Gen 00-05 5 11-26-2004 12:43 AM
