Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 2nd Gen 00-05
Old 10-28-2004, 02:14 PM
podboy3 podboy3 is offline
2000 neon will not go into reverse
i have a 2000 neon and as of the last week or two the car is not wanting to go into reverse, it did it once in a while but now it is doing it more and more.
any ideas or suggestions would be great.
thanks
dan
Old 10-28-2004, 02:20 PM
sorry but i forgot to add it is a 5 speed and when i do try to put it in reverse it feels like a mechanical hang up. like on the older cars when the linkage would jam up.
Old 11-02-2004, 08:19 PM
ToffeeMan ToffeeMan is offline
Had the same problem a few months ago. There is a rubber jacket / collar that protects the opening where the shift stick enters the gearbox. Cost about 50 cents. Its probably torn, and won't let you select reverse.
Old 11-08-2004, 03:58 PM
darien99 darien99 is offline
Re: 2000 neon will not go into reverse
Also check your shift bushings on the ends of the shift cable. Might be torn or missing.
Old 11-25-2004, 11:00 PM
silverneonangel silverneonangel is offline
I'm having the same problem with an '00 5-speed, cannot shift into reverse. Feels like a cam is engaged locking me out of the reverse gate. Any info on the resolution of podboy3's problem?
Old 11-26-2004, 12:43 AM
First thing I would check would the the shift bushings where the cables connect to the transmission.
