Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 08-15-2003, 10:53 PM
cho2drivr cho2drivr is offline
Question 1881 Tempo Speedo/Tranny problem
I have a 1991 Ford Tempo, Auto/AC, 130,000 miles, cruise, GL. The ring gear which drives the speedo cable gear is broken. It is very loose on the shaft. I remember hearing about a two piece gear, split so that you cut the old one off and the new one snaps into place around the shaft. I can't remember where I heard it. Can anyone help? The tranny only shifts when the speedo tells it to!
Thanks,
Keith
Old 08-25-2003, 09:11 AM
Dan_in_WA Dan_in_WA is offline
Send a message via AIM to Dan_in_WA Send a message via Yahoo to Dan_in_WA
You might try asking around at www.tempotopaz.com
I'm sure SOMEBODY has had to do this one. Good luck.
Old 08-25-2003, 02:50 PM
Thumbs up Re: 1881 Tempo Speedo/Tranny problem
Hi, Dan
Yep, I had originally heard about it on that site. I was able to track down a supplier and buy the split ring gear. I am, today, trying to put it on but it isn't quite as simple as it sounds. I am going to write a technical brief for www.tempotopaz.com when I am finished. Thanks for your info!
Keith
99 Pontiac Montana Tranny problems? wilson8260 Montana/Montana SV6 9 12-22-2009 10:16 PM
96 sc tranny problems please help phantom309 SC/SL/SW 6 04-28-2009 03:27 PM
92' S-10 Tranny problem AK47 SRH420 Interior | Exterior | Appearance 3 02-20-2009 04:41 PM
97 speedo/tranny problem bigdinz Taurus | Taurus Wagon 5 11-06-2004 07:50 PM
