Old 08-15-2003, 08:18 PM
gsf1200m gsf1200m is offline
si front sway bar?
Would there be any reason to put on in my STD hatch?
Old 08-15-2003, 10:16 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
STDs had no anti-sway bars at all. DX had an 18mm front, and Si had 19mm front and a rear (soda straw sized). Its actually better to have a smaller front and larger rear. I would try and find a DX front sway and than get yourself like a suspension techniques 22mm rear.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 08-15-2003, 11:15 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Re: si front sway bar?
From what I understand, the civic suspension is set up for either understeer or oversteer (I can never remember which or the difference between the two), but it's best to go with a rear sway-bar first as far as handling goes.
Old 08-16-2003, 02:21 AM
Re: Re: si front sway bar?
I can never remember which it has but I think its oversteer. Bigger rear sway bar helps to counter act that.
However I would get some kind of sway bar period as it reduces body roll and makes your car more stable at high speeds.
Old 08-16-2003, 02:37 AM
cyberfelon's Avatar
cyberfelon cyberfelon is offline
Send a message via AIM to cyberfelon
Re: Re: Re: si front sway bar?
all FF cars have UNDERSTEER, as they tend to not turn as much as you steer, RWD cars have oversteer cuz they do the opposite
Id rather be drifting...
Old 08-16-2003, 10:23 AM
Thanks for the info, I will go down to the junkyard sometime.
I have a 91, would any sway bar from an 88-91 Civic/crx work?
And as for the rear, are there any I could pick up while I am there from any other Hondas or Acuras?
Old 08-16-2003, 11:35 AM
BullShifter's Avatar
Re: Re: Re: Re: si front sway bar?
larger rear sway bars on FWD will help create oversteer. Which is a very good thing. large front will make understeer even worse than it all ready is.
Front sway bar pkmaven E-Class 2 02-05-2003 03:43 PM
Stock Front Sway Bar Already Installed ? SkyWalker Suspension 1 07-16-2002 09:21 PM
Front sway bar extensions Schludwiller Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 12 05-03-2002 10:01 PM
Greasable Front Sway Bar Mount Bushings Schludwiller Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 2 03-08-2002 05:44 PM
why no front sway bar? v_knot Suspension 0 03-03-2002 04:09 PM
