Go Back   Automotive Forums Car Chat > Mercedes-Benz > E-Class
Old 06-19-2002, 10:15 PM
pkmaven pkmaven is offline
Front sway bar
One of the easiest changes you can make to a 124 body Mercedes is the replacement of the front sway bar. If you would like tighter control and better cornering from your car's suspension, you can replace the front sway bar with the one from the Mercedes "Sport" package. It is slightly larger in diameter, and along with the four new bushings it provides a noticeable improvement in the car's handling. P.
Old 06-23-2002, 12:21 AM
Benzaholic Benzaholic is offline
Several original models exist
I think there were several different front sway bars used on 124s. I believe my 89 300CE uses the thicker bar from the 400E, which may be the same size as the "sport" version, and I understand that the 500E has an even thicker one.
I also believe any one of them can be installed in any model 124.
I haven't spent much time in a 124 sedan, so I can't really say how noticeable the 400E sway bar is on my coupe.
Old 02-05-2003, 03:43 PM
124 sway bar
The sway bars included in the "sport" option for the sedan are the o.e. bars used on the CE and the convertible. The V8 sedans use different bars because of their increased weight. I recently saw the pdf file for all MB sway bars and was surprised at the number of sway bars available. P.
Front Sway Bar??? funnylittlman Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 09-05-2002 02:30 PM
Stock Front Sway Bar Already Installed ? SkyWalker Suspension 1 07-16-2002 09:21 PM
Front sway bar extensions Schludwiller Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 12 05-03-2002 10:01 PM
Greasable Front Sway Bar Mount Bushings Schludwiller Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 2 03-08-2002 05:44 PM
why no front sway bar? v_knot Suspension 0 03-03-2002 04:09 PM
