Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 03-04-2002, 02:53 PM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
Front sway bar extensions
Is anybody with a suspension lift running front sway bar extensions? Any impressions, opinions?
Old 03-04-2002, 03:28 PM
The X Factor The X Factor is offline
Send a message via AIM to The X Factor
I am. After installing the 3" AC lift the front swaybar was aiming downward at a bad angle. So I went to the local autozone and picked up some longer extensions. Here is a pic......
Everything is going fine and im happy with it. Before installing the longer extensions the fron sway bar was virtually impossible to more. Now it has more the stock "feel" to it.
Old 03-04-2002, 03:55 PM
XTerra Guy
Do you have a part number, or description that I can tell them to get those. How long are they, size, etc.
I guess I can always take the part there, but any additional info will help.
Old 03-04-2002, 04:05 PM
I dont have the part number sorry. They were longer than I liked but that is nothing a little cutting couldnt fix. I did cut the middle sleeve down about an inch, and it is still about a half inch longer than the stock sleeve. That was all I needed to fix the problem. If you would like some better pics or closer pics let me know.
Old 03-04-2002, 05:40 PM
scott.com scott.com is offline
Question Which witch is which
So which part in the pic is the front sway bar?
Old 03-04-2002, 05:56 PM
rrdstarr's Avatar
rrdstarr rrdstarr is offline
Cool
It's the black thing (swaybar) with the red squishy things (swaybar bushings) on the gold thingy Sway bar extension rod)!
We don't give a damn how loud your stereo is!
Did you read your owners manual yet?
V.P. of PNWX
Old 03-04-2002, 10:49 PM
Craigs_Tonka Craigs_Tonka is offline
I'm in the process
of making some of these up right now. I went to Lowes (Home Depot works too) and bought some 3/8" bolts 5 1/2" and 6" long as well as bulk 3/8" i.d. steel sleeve that I can cut to size.
The 6" bolts will likely be the ones for lifted trucks and the 5 1/2" will be for trucks with cranked torsion bars.
I also got some 1/2" wingnuts that I'm welding 3/8" nuts to. That way I can remove and re-connect without tools.
SLR 3" Lift, SLR IV Intake, SLR Steering Stabilizer, 32" BFG MT km's, Warn Premium Locking Hubs, Gibson Exhaust, Custom Rock Sliders, Custom Safari Rack, CO2 Air Tank, Daylighters, CB, with more to come.
Old 03-05-2002, 02:18 AM
Kerensky97's Avatar
Kerensky97 Kerensky97 is offline
Thumbs up
Goto www.Energysuspension.com and look for sway bar bushings in the cataloge.
I'd give the direct link but their having server problems right now.
They sell sets of sway bar endlinks in 3/8" and 1/2" diameter and you just choose how long you want the sleve in the middle, I think the range is from 1" (stock Xterra) to 3" in half inch increments. Plus you get new urethane bushings to go with it.
All for under $20.
Plus they are a major bushing supplier so most 4WD shops can special order them if you give them a part number.
I just ordered me a set of stock length ones and got some 3/8" knobs from Lowes to make my Quick Disconects.
The cost was cheap and they're high quality parts.
-Dustin
2000 Nissan Xterra XE, Sport Package, 4X4, Automatic.
And yes its better than yours.
Old 03-05-2002, 08:56 AM
Yeah, I was aware
that Energy Suspension carried these. The only reason I'm building mine is I already have all the bushings from my lift kit, so I just needed the bolt and bushing and that was easy enough to take care of for about $4.
Besides, I like building $hit. :sun:
Old 03-08-2002, 02:02 AM
venx's Avatar
venx venx is offline
what about the rear sway bars has anybody have a pic of them. Now i know which are the front ones but not idea on the rear ones, also will it make my x ride a little better if i put the front sway bar ext, i am running 32 mud bfg and i have my trosion bars cranked, about 12 turns=1 1/2"
life is short party naked!!!!!
Old 03-08-2002, 09:52 AM
XTerra Guy
swaybar
Here's some info for you.
http://www.howstuffworks.com/question432.htm
Xterra4x4.com and the Xterra Offroad Webring
Old 03-10-2002, 04:57 AM
venx's Avatar
ok i got the answer to my wuestions from my local 4x4 dealer which told me the function of them and everything else that i need it to know anyways thanks a lot Schludwillerfor your answer you have been very helpfull as well as everybody else.
MF (Venx)
Old 05-03-2002, 11:01 PM
Just thought I would
update this with a picture of my quick disconnects I made that include longer spacers to level out the sway bar angle.
Front sway bar pkmaven E-Class 2 02-05-2003 04:43 PM
Front Sway Bar??? funnylittlman Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 09-05-2002 03:30 PM
Stock Front Sway Bar Already Installed ? SkyWalker Suspension 1 07-16-2002 10:21 PM
Greasable Front Sway Bar Mount Bushings Schludwiller Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 2 03-08-2002 06:44 PM
why no front sway bar? v_knot Suspension 0 03-03-2002 05:09 PM
