View Poll Results: WOULD MY GTP BE ANY LOUDER IF I TOOK THE CAT OFF AND THE RESENATOR AND PUT IN A PIPE?
YES 7 63.64%
NO 0 0%
Multiple Choice Poll. Voters: 11. You may not vote on this poll
Old 08-14-2003, 02:55 AM
TEAM xTREME GTP TEAM xTREME GTP is offline
Send a message via AIM to TEAM xTREME GTP
Thumbs up 12 Hp After Throttle Body Screen Removed
I DYNOED MY CAR LAST WEEK AND IT'S HP AT THE WHEELS WAS 278 THEN I WAS SCREWING AROUND WITH MY INTAKE AND I WANTED TO CLEAN THE SCREEN IN MY THROTTLE BODY AND I TOOK IT OUT CLEANED IT AND DIDNT PUT IT BACK IN BECAUSE I WANTED TO SEE IF THERE WAS A DIFFERENCE, AND IT PULLED ALOT HARDER SO ABOUT A WEEK LATER I DYNOED IT AGAIN AND IT WAS 290 AT THE FRONT WHEELS. WRITE BACK ANY COMMENTS ON WHY THIS HAPPENED THANX!
FUCK FORD!!!!!!
Old 08-14-2003, 07:32 AM
buymeabmwm3 buymeabmwm3 is offline
I work at Ford diesel powertrain, and we put screens on our intake manifolds. I'm pretty sure the only reason is for sound quality concerns. So long as you don't mind the louder sound, I say keep it off.
1992 BMW 325i conv.
FOR SALE!!
IM me for more info. $6300 /obo
2005 Ducati Monster 620 i.e.
2005 Toyota Tacoma V6 4x4 Double Cab, TRD Off-Road - FINALLY HERE!
Horsepower is 100 ewoks poking you with pointy sticks.
Torque is one wookie pulling your arms out of their sockets.
Old 08-14-2003, 09:33 AM
'00' GTP '00' GTP is offline
That screen is in there to redirect the air to a less turbliant flow. it restricts the air flow by 15-20% that was one of the first things that I did.
OK.... WTF do you have done to your car? for you to not know about the screen, or the exhaust, and aparently you have factory exhaust. what have you done?
2000 Black 4 Door GTP
3.4" pully
FWI
14.5 stock
2003 Red Accord Coupe
V6 6-speed
car-stats.com saies it runs 14.7
Old 08-15-2003, 08:31 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Better gas, Cooler weather, Cooler car, Different dyno/guy dynoing. These r some things that can change dyno results.
For that HP range look at my sig. I dynoed 291 fwhp 3xx lbtq
Old 08-16-2003, 09:46 AM
what pully do you have on your SC?
3.4" pully
FWI
14.5 stock
V6 6-speed
Old 08-16-2003, 05:04 PM
Ripn12s's Avatar
3.1 DUB Daily
2.9 only ran twice
Old 08-17-2003, 06:43 PM
Al'sCar Al'sCar is offline
off the topic, but i want to get a GTP and wondering waht kind of pistons come stock on the GTP, forged or cast, and how long will it last w/ the boost?? THANKS guys.
Old 08-17-2003, 07:04 PM
Ripn12s's Avatar
I'm pretty sure they are cast. But you could upgrade with the Diamond Coated/uncoated Forged Pistons.
I run 12 lbs of boost daily and doubt I will ever need to upgrade. Most people lose a piston when they run one of the cylinders too lean and crack the piston. One thing that always seems to destroy pistons is when people try to maintain speeds of over 100mph for an extended time period.
Once you get a GP you'll be happy, and I dont think you'll have to worry about losing a piston.
Good Luck
Tim
Old 08-18-2003, 10:22 AM
GP's are an all around perfect car. you won't be sorry
3.4" pully
FWI
14.5 stock
V6 6-speed
Old 09-07-2003, 02:43 AM
ryuhito ryuhito is offline
Re: 12 Hp After Throttle Body Screen Removed
You took out the throttle body screen? How tough was that? Do you think I'd gain anything on my NA (no supercharger) 3800?
Old 11-03-2003, 11:39 AM
infernomp5 infernomp5 is offline
I just removed my screen on a 2001 g.p with a 3.1 and i was sceptical at first about removing it, but now that its gone and i think about it, good idea ! It has to restrict alot of air coming in and thats not good.
Old 11-03-2003, 04:44 PM
The Burning Rom The Burning Rom is offline
Send a message via AIM to The Burning Rom Send a message via MSN to The Burning Rom Send a message via Yahoo to The Burning Rom
There have been some guys on www.clubgp.com that have had problems with their cars after removing the screen. Be careful not to destroy it..in-case you have to put it back in.
And as Ripn12s pointed out, there are many factors that could have influenced the dyno results. I highly doubt that removing the screen gained you 12hp.
And the OBVIOUS answer to your question....YES, it would be louder if you removed restrictions in your exhaust.
www.wicgp.com <- Wisconsin Grand Prix Club
1999 Black Grand Prix GT Coupe
1990 Red ASC/Mclaren Grand Prix Turbo Coupe
1990 Metallic Blue & Silver Grand Prix LE Coupe
1979 Blue Dodge Ramcharger
Old 03-07-2004, 11:39 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Ripn12s, that would blow a piston if the car is not in high gear, in high gear the rpms should be around 2900 and that would not harm the engine(to my humble knowledge).
The Burning Rom, good to see you again.
Al'scar
If you are going to put a lot if strain on your car go to http://www.intense-racing.com and check what they have for blocks, pistons and heads.
I blew my previous engine but was because I rev it up to 5500 for more than 15 mins(my tranny when to neutral) and it screwed the engine good. But for most of the guys I have read here that have moded lighlty or moderately their cars what the block brings from factory has served them more than well. In my case I am using a Reman Mr. Goodwrench engine with some moding and it only has 2 months so I do not really know if this one will get problems from the moding that I have made to it.
Old 03-07-2004, 05:47 PM
gtgp97 gtgp97 is offline
Send a message via AIM to gtgp97
my car is around 3500 rpms at 100...maybe thats because its a gt not a gtp so the gearing is different..
Old 03-07-2004, 06:03 PM
kilroypr's Avatar
gtgp97, Before my tranny died my car was like yours. When I got the new one I got it with the final output gear ratio to be 2.93 instead of the OEM the car had(3.29). If your car has a 3.29 transaxle then is behaving normally if it is 2.93 then I am nor sure because mine increased the cruising speed from 90 to 105 when I lowered the transaxle from 3.29 to 2.93 at 2900 rpms. That depends on the transaxle final gear ratio not if the car is NA or FI. What the FI or NA makes is the car quicker to get there.
'00 cavalier, odd noise and oil in air intake/throttle body warik Cavalier Problem Diagnosis 4 04-23-2009 07:11 PM
Throttle Body Screen Removal 2000blazerls Monte Carlo 16 02-14-2007 10:59 AM
Throttle body screen JayRodd016 Grand Prix 5 07-07-2005 12:21 PM
Throttle Body Screen Gomer4ever2005 Grand Prix 3 02-13-2005 01:13 PM
Throttle Body screen removal ipec Grand Prix 20 03-07-2004 11:20 AM
