Old 06-18-2003, 03:29 PM
ipec ipec is offline
Throttle Body screen removal
Is removing the screen on the Throttle Body an OK modification? I did so, and it did make a difference, but isn't the screen there for a reason other than consistent airflow? Is there a chance that something (debris) could get in the air hose coming from the air box? Or is that the air filter's job-to keep crap from going in there?
-IPEC for life
Old 06-18-2003, 04:07 PM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
I'm not sure. I think that it might be there to keep dirt out if you take the air filter assembly off to work on the engine. If you have a quality folter in, I don't see any harm in it.
Old 06-18-2003, 07:34 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
The screen is used to direct airflow properly into the intake so you get the right fuel air mixture! You wanna remove it go ahead but I dont see any possible benifit in doing so! It is not an back up air filter look at the size of the holes if it gets thru the airfilter than it was meant to be sucked into the engine.
Old 06-18-2003, 07:50 PM
Yeah, you said it-it directs the airflow into the MAF sensor. From what I hear, the screen itself cuts the flow down about 15-20%. I know I'm not dillusional, and it has been damn hot out, so I know lower temps have nothing to do with it; but that car has more "ups" than it did with the screen in place...!
-IPEC for life
Old 06-19-2003, 01:49 AM
scrubin63125 scrubin63125 is offline
Everyone in my club has thiers removed the only people that have had any sort of problems were people with 1997 GTP's. I would say that if 50+ people are not having problems after having thiers removed for a couple years there is no harm.
Old 06-19-2003, 09:56 AM
02 GTP 02 GTP is offline
Banned
That screen is there for a reason. It is there to help fuel mixture and as well as keep debris from going through your engine. I don't think that is a ok mod. because of the chance of dirt or debris getting into the engine. Just my..
Old 06-19-2003, 10:05 AM
'00' GTP '00' GTP is offline
I have a 2000 GTP. I removed mine, and it was clear, no dirt, or debris on the screen. I figure, if there is no dirt on it after 3 years and 47,000 mi. I don' figure that there will ever be dirt on it. (noticeable gain)
2000 Black 4 Door GTP
3.4" pully
FWI
14.5 stock
2003 Red Accord Coupe
V6 6-speed
car-stats.com saies it runs 14.7
Old 06-19-2003, 10:46 AM
Right on! Although, I did finally notice an adverse effect... Yesterday, I started my GP, and after about 4-5 seconds (the engine was still pretty warm) the car started shaking pretty good. I looked right away at the RPM's, and they were swinging up towards about 1000-1100, so I assume, it was a lot lower, and the car was maybe close to turning off. If that's not a rough idle, I don't know what is. But it has only happened once, so I won't think it's anything to worry about unless it keeps occuring.
-IPEC for life
Old 06-19-2003, 11:33 AM
that is the only adverse effect to taking the screen off. the screen redirects the air, and without it at low idle rpm's it will be rough
3.4" pully
FWI
14.5 stock
V6 6-speed
Old 06-19-2003, 01:12 PM
carnutcass's Avatar
carnutcass carnutcass is offline
Check out www.zzperformance.com . They've got some useful info about this mod. The following is from their site.
The stock Throttle Body can be restrictive even on a stock engine. The factory installs a screen in the inlet of the Throttle Body to straighten the air as it travels into the MAF sensor. This provides a smoother idle and more consistent fuel delivery. For Maximum performance this screen is disruption in the airflow that can be removed with little or *no adverse effects. On the flow bench we have realized a 10-15% increase in airflow by removing the screen.
Begin by using two sharp objects like screws to pinch the retaining C clip together. Pull towards you for removal. Insert a small object like a screw or flat head screw driver into the edge of the screen and pry it out being careful not to damage it.
* In 97 and 98 GM incorporated the MAF channel into the TB itself. On these cars we have noticed that some of them will idle rough without the screen in the throttle body. If you experience this, simply replace your screen.
Old 06-19-2003, 02:29 PM
Yeah; that's where I got the idea... It makes a difference, I swear by it. At least it made a diff in mine. I might be crazy now, but I can almost say that my shifting is more crisp too. Could be the car finally breaking in though too, I suppose.
-IPEC for life
Old 06-21-2003, 09:31 PM
rubberman rubberman is offline
Took mine out today. It was a tough booger to get out.
Old 06-23-2003, 08:28 AM
A guy at the Grandprix.net forums told me that Delco Alphi said its better to leave the screen in. It could possibly throw a code and/or lower HP numbers. So far i had no codes and seems to drive perfect. I have gone about 100 miles with no problems.
Old 09-07-2003, 02:09 AM
ryuhito ryuhito is offline
I'm gonna pull my screen tomorrow. Anyone have a pic of the location on a N/A 3800? It would be nice to have a little guidance before I start poking around.
Old 09-07-2003, 11:38 PM
Da_FunkyB Da_FunkyB is offline
Send a message via Yahoo to Da_FunkyB
Right at the inlet to the throttle body from the airbox, right?
I can understand how both cases are important... the screen restricts airflow, but at the same time smooths it (which is important b/t/w )... so how about someone figures a way to accomplish the same goal (smooth flow) without the reduction in flow. dosen't seem like a complex problem - I'll see what I can find and get back.
