Old 08-13-2003, 10:54 AM
streetdreams420 streetdreams420 is offline
Send a message via AIM to streetdreams420 Send a message via MSN to streetdreams420
throttle sensor problem
okay just finished my dx intake swap to pgmfi and my throttle sensor was broken, I went to the scrap yard and all the si civics and crx throttle sensors are gone so I was wondering if I can use one off of somthing else can anyone help ??
Old 08-13-2003, 04:36 PM
sbninja sbninja is offline
Mine had broken also (Read: pain in the ass) I did a search for the throttle position sensor (used parts) on the internet(about 2 yrs ago) recieved emails back with price qoutes picked the best one and called up and ordered over the phone.
they sent me an entire distributor with T.P.S. on it. I had to grind in slots and unscrew the screws.
Sorry don't rember the actual website , but is was a junk yard.
Old 08-13-2003, 04:41 PM
here try requesting a part price here
http://www.d-a-p.com/
Old 08-13-2003, 04:49 PM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Ok - having driven a car that someone reset the TPS on, all I can say is find a throttle body with the TPS still sealed on it. Reason being that you will never get the setting right without the correct equipment - that being the reason why Honda seals the screws when they factory fit them. For me it was a case of spending the equivilent of US$50 and bolting a complete throttle/TPS unit on and I've never looked back.
BTW sbninja - TPS is on the throttle, not the dizzy
Cheers
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 08-13-2003, 08:40 PM
Oops! yup I meant throttlebody!(don't know what I was thinking!)
Old 08-13-2003, 10:13 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
hey Setanta, how do you know if your sensor is on wrong? I had to put a new one on my ZC because it came broken. I put a new one on and it was throwing the TPS code. I adjusted it a little and now theres no code. Does this mean its seated correctly or could it still be wrong?
P.S. What does setanta mean? is it spanish?
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 08-13-2003, 11:12 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
any civic MPFI TPS wil work..
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 08-13-2003, 11:15 PM
Cheers
All you need to do is set the TPS so that it reads 0.5 volts closed throttle and 4.5 volts WOT..
-2000 Civic Hatch
-1998 Lexus SC300
Old 08-14-2003, 02:09 AM
Setanta's Avatar
Mine had the bolts removed and new ones screwed in. It also idled at 2500rpm hot (ouch) and when I fixed/replaced the cold idle valve the idle jumped up and down all over the place. Replacing the TPS solved it and it idles stock as a rock.
BTW - I know about the voltage settings - but you can never quite get it spot on - I tried along with a few others and got nowhere - almost, but not quite and the difference between trying to fix it and bolting on a new TB was 15bhp! Beats me why, but seeing as it cost me next to nothing, I'd suggest the replace option every day of the week
Setanta is Irish. It's the non-warrior name of Cuchulainn, an ancient legendary warrior from Ulster. I've used it online since I first logged on, mostly from a fascination with Celtic mythology that I developed at Uni.
Cheers
'99 PY DC2R
'85 BBS BMW E30
2001 Yukon O2 Sensor Problems belbers1 Yukon 10 02-10-2010 10:23 AM
O2 sensor problems ? mandtra Avalanche 3 09-25-2009 02:52 PM
Question: 2003 with W8-sensor problem? loocha '97+ 5 09-01-2009 09:00 PM
Throttle or Oxygen sensor problem? Postman1955 General Discussion 3 06-07-2004 05:40 AM
throttle position sensor problem felnblu '88 - '91 Civic | CRX | Wagon | Shuttlee 2 06-06-2002 04:51 PM
